Hi Denis,
I have done several comparisons with the AP160 and 140. Also with the CFF250 and Meade 12" ACF.
With a BV installed the 185 compares well with the 250 and 12" when viewing the planets, but with the advantage of being free of thermal equilibrium issues.
The CFF does much better than the Meade in this regard, but summer temps require the fans to run.
The 185 compares well against the premium APO's unless you have superb seeing and can use very high powers.
The AP's don't break down in image quality easily, while I feel the 185 might not hold up as well if compared directly at 400x+. I don't have the seeing to prove this, but I can extrapolate from experience that this would likely be true.
If you are a purist about color correction, you might also prefer to spend the extra 10-15K over the Askar to obtain that perfection.
I don't see any obvious color on Jupiter, Venus or the Moon up to around 430x.
It mainly shows up on brighter stars when viewing out of focus, but is also one possible culprit that could cause image degradation at high powers.
The 185 shows more faint stars than the smaller AP's when viewing globulars and open clusters at low to mid powers. They have that look of fine glowing dust refractors are known for. Hard to beat aperture once a certain optical quality level is reached.
The 185 also shows the dozen or so faint stars around the Trapezium in M42 more easily than the 160.
I would not expect an F/7 triplet with ED glass to be as well corrected as the AP's (F7.5 and using FPL-53), but Askar got the figure and lens cell design right so its performance is as good as it should be for this level glass.
