Best way to repair a broken finderscope bracket?
12 replies to this topic
#1 ericb760
ericb760
  • Loc: Palm Springs, CA
Posted 09 July 2024 - 02:59 AM
One of the scopes I picked up recently arrived with broken finderscope bracket. The break is very clean and I can put the pieces back together so well that I can't even see the break. I'm thinking that JB Weld is the way to go here. Will that work, or is there a better way to put these pieces back together?
Finderscope Bracket
#2 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 09 July 2024 - 06:51 AM
I would buy a new pair of rings from AliExpress - they're only a few dollars - then if necessary drill and tap holes to suit that bracket.
See for example https://www.aliexpre...rch|query_from:
... there are many more...
Edited by luxo II, 09 July 2024 - 06:57 AM.
#3 AstroPhotog
AstroPhotog
  • Loc: Wake, NC
Posted 09 July 2024 - 07:27 AM
It looks like metal. +1 J-B Weld, I used it to attach supports to stiffen an eq-2 tripod almost 40 years ago and it's still there. smile.gif
Edited by AstroPhotog, 09 July 2024 - 07:36 AM.
  • ericb760 likes this
#4 clamchip
clamchip
  • Loc: Seattle
Posted 09 July 2024 - 09:31 AM
When the parts fit back together well like your example I use Superglue.
I got the idea from nurse Mendy. She made me a believer when she glued a broken C8 bracket for me to test to destruction. That was a long time ago and still holding fine.
Robert
Edited by clamchip, 09 July 2024 - 09:36 AM.
#5 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 09 July 2024 - 09:42 AM
My experience with superglue is that it deteriorates in a few years and the pieces fall apart.   Maybe superglue to hold the pieces together then JBWeld or epoxy repair extending a bit in both directions from the break.
  • ericb760, Kasmos and NinePlanets like this
#6 Orion68
Orion68
Posted 09 July 2024 - 03:29 PM
An epoxy like JBWeld should do the trick.  I received a scope from Goodwill with the same type of damage. Using epoxy fixed it and it is still holding.
#7 Bungee
Bungee
  • Loc: South Central Missouri
Posted 09 July 2024 - 10:51 PM
It's tedious work, but I drill and pin my pieces before JB'ing them. Drill the holes a little larger than the pin material, dry fit to check the alignment, then coat the pins and mating surfaces. Little wire nails make great pin material.
  • ericb760 and AstroKerr like this
#8 mich_al
mich_al
Posted 10 July 2024 - 09:30 AM
How do ya properly locate a pin for a repair like this ?
#9 1939Dodge
1939Dodge
  • Loc: Danville, Pa.
Posted 10 July 2024 - 09:39 AM
Use plain old epoxy. It will work fine, and allow EXCELLENT alignment of the pieces.
  • Davemartin888 likes this
#10 NinePlanets
NinePlanets
  • Loc: High and Dry
Posted 10 July 2024 - 09:44 AM
Yep. Super Glue is temporary. You might get 3 years out of it, base on extensive experience with coffee cup handles...
If you don't to replace it, and you don't want to drill it and screw it, then I wouild go with the JB Weld - nice globs all around both pieces at the joint.
#11 MarkMittlesteadt
MarkMittlesteadt
  • Loc: Weston, WI. USA
Posted 10 July 2024 - 09:51 AM
JB Weld. I cut apart my my 8X50 RACI finderstalk to drastically shorten it. I removed the center section and then put the top and bottom together with JB Weld for metal.
I did drill and tap holes for threading small bolts in through the bottom, but they aren't really necessary. I think I did it because I was impatient and wanted to use it shortly after it dried to the touch, but not yet fully cured.
Edited by MarkMittlesteadt, 10 July 2024 - 10:09 AM.
#12 Bungee
Bungee
Posted 10 July 2024 - 11:12 PM
I look for the thickest section and use micro bits.
Here's my latest repair. You can see the part was very small. The pins add strength without leaving a glob of cement.
20240710 230207
20240710 230218
Some day I'll touch that with a little black paint
Edited by Bungee, 10 July 2024 - 11:17 PM.
  • ericb760 and catboat like this
#13 ericb760
ericb760
Posted 11 July 2024 - 03:21 AM
This mod makes a lot of sense. Thanks for the idea.
  • MarkMittlesteadt likes this
