what is the benefit between the Antlia 2.5nm and 3nm filters?
Astrophotography
5 replies to this topic
#1 John Berger
John Berger
Posted 14 July 2024 - 12:44 AM
assuming I use an F/6.4 system
would it be better if I get the 2.5nm h-a, or should I stay with the 3nm?
there doesn't seem to be enough reviews of the 2.5, so I'm a little nervous about purchasing that
I'm going mono and choosing my first narrowband filters; looking for the best, highest contrast, H and O filters besides Chroma and Astrodon
how much of a benefit would it be, buying the 2.5 over the 3?
#2 daveco2
daveco2
  • Loc: Torrance, CA
Posted 14 July 2024 - 06:43 AM
I would venture to say you will not see any difference in the final image with those two bandwidths.
At my Bortle 8 site, I see no difference between 7 and 3 nm.
  • John Berger likes this
#3 Avgvstvs
Avgvstvs
  • Loc: Southern Hemisphere
Posted 14 July 2024 - 06:56 AM
It depends on your levels of light pollution. With more light pollution you benefit from narrower band widths. There's probably not much in it between 2.5 and 3 nm unless you are bortle 7 or higher. Besides how accurate are the numbers compared to the actual product? Many times batches differ. And it could be marketing to rate filter at 2.5nm to justify the extra cost or make it seem better than a 3nm filter. Overall, there's not much in it
Edited by Avgvstvs, 14 July 2024 - 07:02 AM.
#4 Drothgeb
Drothgeb
  • Loc: Maryland
Posted 14 July 2024 - 04:20 PM
The 2.5nm filters use a better glass, so transmission is higher. They also come with individual test results. My 2.8’s are made with Ohara glass, and both the Ha and SII are above 98%. The OIIII is over 96%. But the OIII does halo with bright stars, whereas the 3nm OIII doesn’t
Edited by Drothgeb, 14 July 2024 - 04:22 PM.
#5 John Berger
John Berger
Posted 14 July 2024 - 10:13 PM
why does the 2.5nm h-a filter graph show wider transmittance bandpass than the 3nm?
I see what you mean about the higher transmittance, and I like that a lot
but the apparent wider bandwidth is confusing
#6 HubSky
HubSky
  • Loc: Virginia Beach, Virginia
Posted 15 July 2024 - 12:19 AM
It's just the scale.  The bandwidth is FWHM, full width half max.  So go half way up the graph and measure there.  On the 3nM graph, each division is 1nM for a total of 3nM (3 divisions).  On the 2.5nM graph, each division is 0.5nM for a total of 2.5nM (5 divisions).
Also tagged with one or more of these keywords: Astrophotography
