Focuser motor Issue/Questions - Can you manually calibrate the focuser motor
Celestron
4 replies to this topic
#1 ordnance11
ordnance11
Posted 16 July 2024 - 08:37 AM
I successfully installed the focuser motor on my Celestron 6SE. My issue now seems to be in the calibration. I'm using the CPWI utility and it doesnt stop when the turning stem hits the. travel limit. I've observed that the stem does travel when I use a game controller to direct the motor. I haven't checked the firmware yet, so I might do that next. I downloaded the ASCOM driver and the old Celestron motor utility. Can you manually calibrate the focuser? Set the stem at one end of the stop Assign a value like zero, then have it travel to the other end?
#2 Notdarkenough
Notdarkenough
  • Loc: 5000' ft @ 41° North
Posted 16 July 2024 - 01:11 PM
The Celestron Focus Motor? Or, some other focus motor?
#3 ordnance11
ordnance11
Posted 16 July 2024 - 01:17 PM
The celestron focus motor.
#4 mlord
mlord
  • Loc: Ottawa, Canada.
Posted 16 July 2024 - 02:53 PM
The $12 Homebrew clone of it, yes.  The $250 real one, no.  :)
It has to be run and detect the stops automatically.  If that's not working, then there's a mechanical issue somewhere.
#5 ordnance11
ordnance11
Posted 16 July 2024 - 05:01 PM
I've tightened the clamp as far as I dared. The motor is mounted snugly and it's not binding, an improvement on the first time I tried it. The motor keeps running when the stem hits the stop. The stem will move when I run the motor, as long as I don't hit the stop.
I decided to run the motor from an initial stop out position and then travel it out toward the other stop position. I was using the CPWI focuser control and a game controller and I was keeping an eye on when the stem stopped. I noted the number at the start. I noted that it hit a max number then started from zero before hitting a value at the end:
+ 8800 = Travel out position
+ 59995 = Max value
- 21300 = Travel in position
Arbitrary values based on whether the stem is turning toward the positive sign or not.
I got a value of 43261 when I trained the scope on an object 1/4 mile away it went into focus. I supposed I managed a rough calibration. Good enough, I suppose.
I also put in in a ticket to celestron about it. I'll see what they say.
Edited by ordnance11, 16 July 2024 - 05:03 PM.
Also tagged with one or more of these keywords: Celestron
