The issue of whether scopes should be nulled in green or red has been raised in another thread. Correction color choice isn’t the theme of that thread, but I’m sufficiently interested in the question and so I present it here. The title is posed in the form of a question because I don’t think it’s been critically examined sufficiently to put in the form of a statement, and I invite that necessary critical examination so that the question, modified into the form of a statement, can be confidential declared or discarded. Since some discussion has already been made on the topic I’ll repeat those opening remarks to save both time and effort.
I wrote the following in the aforementioned thread:
“I am beginning to wonder if the conventional wisdom advocating nulling telescopes in green is completely wrong.
Stars radiate across the entirety of the spectrum, but the most commonly used classifications for stars are based upon their peak stellar spectra. Tallying the observable stars, ie., the ones we look at, it’s found that 95.6% of stars emit in the yellow (G, 7.6%), light orange (K, 12%), or orangish-red (O, 76%) in wavelengths longer than green, and that only 0.12% emit in the blue dominated wavelengths shorter than green. The remaining 3.61%, the white and yellowish-white A and F stars, are agnostic.
What’s worth paying closer attention to is that 76% of stars are classified as orangish-red stars with spectrums significantly closer to red than green. There are no green, cyan, indigo, or violet stars. The spectrum for Mars peaks around 640nm - it’s not for no reason it’s called the “Red Planet”. Some planets, like Jupiter, also favor red, though not markedly so, and others, like Saturn, lean moderately green, though like Jupiter only a bit.
So why null in green? I’m unable to postulate any plausible astronomical reason to do so since three quarters of the observable stars should be better resolved in a scope nulled in red. The invariably stated reason to null in green is because that’s the color our eyes are most sensitive to. So what? It would seem that we are nulling for a color conspicuously absent in the night sky at the expense of the colors that are abundant to accommodate our eyes to see what isn’t there. Our eyes resolve best in green because that’s the color of vegetation, not because it’s the color of starlight.
Consider the average star, emitting predominantly in the orangish-red spectrum, and the light from that star passing through a scope nulled to a very high standard in red. The light from that star focused through that scope will reach the observers eye well corrected around it’s dominant orangish-red color, and less so for colors less dominant. The focused light from that same star, but now through a scope nulled in green, will be well corrected around non-dominant green, but less so around its predominant color spectra, orangish-red. So, in essence, the green nulled scope will under perform optically in the predominant orangish-red spectra of our observable celestial neighborhood because it’s nulled in a part of the spectrum where there is far less light emitted. We could call this less-well corrected orangish-red part of the spectra in the green nulled scope “red bloat” because optically speaking it is, and “unfortunate” because stars seem to have strong proclivity for it.
I can appreciate the logic of nulling a terrestrial spotting scope in green, say for orchid hunting, because that’s the dominant spectra in the environment it will be observing in. Applying the same logic, nulling astronomical telescopes scopes towards the red side of the spectrum would seem to answer best because that’s the dominant spectra in the environment it will be observing in.
Edited by Polyphemos, 19 July 2024 - 01:04 PM.
