I have an issue with PHD2 in NINA not automatically starting to guide when starting an imaging session.
The imaging session becomes active however it will start capturing the images with guiding not active- PHD2 loads on initial startup but it never auto selects a guide star or begins to guide. If I start exposing PHD2 manually and then manually select a guide star it works as expected. However this is not ideal as it worked as expected sometime back so I suspect that something has become unconfigured like a check box or some other problem. Any clues as to how to resolve this issue and what to check?- I did think that the PHD2 server setting was turned off but this is not the case- it seems that NINA is not correctly integrating with PHD2 or vice versa.
I don't know whether a complete reinstall might be the way forward however my relectance is that sometimes this might not fix the issue and sometimes make an issue worse.
Please let me know your thoughts.
