I just ordered the 8" Omegon Dob, concenter collimation eyepiece and SVBony yellow line eyepiece set. Can't wait for them to come!
While sky is still pretty bright smashing low magnifications, you'll want to add also this to replace cliche and really no good in 1200mm focal length telescopes 25mm Plössl:
https://teleskopy.pl...roducts_id=2012
It gives literally 60% wider view fitting Pleiades properly and making finding targets lot easier:
https://astronomy.to...|1||&messier=45
And if you intend to visit less light polluted places for more serious deep sky observing, RACI finder is neck saver allowing looking into it for long times:
https://teleskopy.pl...roducts_id=2028
With continental Europe having basically only nuclear waste of ergonomics straight through neck pain finder equipped telescopes there must be some nuclear contamination/fallout from SkyWatcher selling only them...
Except for very few positions it's simply pain in the neck and trying to see near zenith through it needs you to be contortionist.
Better external/mechanical finish (grippy part to avoid dropping eyepiece at winter with cold fingers and gloves) Red line would have been actually cheaper on Svbony site.
Anyway would have been better to get individual ones instead of whole set.
15mm will simply crap itself in f/6 telescope: https://telescopicwa...line-eyepieces/
And 20mm is rather not usefull focal length in 8" Dobson.
After 2" wide view eyepiece of roughly 30mm next good step for basic eyepiece set would be at 12-15mm level.
(combination of magnification, exit pupil/surface brightness and wide enough for most deep sky objects)
For quick adjusting of primary mirror alignment laser collimator with Barlow would be one of the easiest by allowing seeing effect of adjustment to rear of telescope:
Unless you have gorilla's arm length, or giraffe's neck, it's little hard to both be able to look into focuser and have fingers on primary mirror adjustment knobs at same time.
(laser alone has many inaccuracy sources)
If you have spare time in weekend might want to consider visiting astronomy meeting just south of Tampere in Valkeakoski:
https://www.ursa.fi/c2024/yleista.html
And if you have any interest in Moon, I would have couple spare S&T Moon maps, which I would rate as the best general lunar chart:
https://shopatsky.co...map-of-the-moon
I bought five at once because shipping costs would have made price of one 40-50€. (for five price per piece ended around 23€)
Cloudy Night band would be awesome! Rogue Planet would also be a good name. There are so many cool space related terms to use in a band name!
Well, "4000 Rainy Nights" song name of Stratovarius is unfortunately fitting for bad side of weather...
And you'll certainly meet "Cold Winter Nights" + maybe some "Against the Wind".
And "Dead Moon Rising" of Sentenced is pretty nice song name.
