This is a project I finally got some free time to work on, a 10 inch F/5 Chief. It’s partially obstructed because I doesn’t do well fully unobstructed. However only haff the secondary obstructs and there is still improvement to the diffraction disk. It’s a work in progress. Got my primary back from the coater so time to get on with it.
I use a tripod support, a 1.5 inch aluminum angle (7) and two ¾ X1/8 supports giving a decent damping time. The upper assembly screws on to a hardwood block (not shown) screwed to the aluminum angle using a thumb wheel (4). It is prevented from rotating by plate (5) and nut (6). A helical focuser (1) is fastened to the lens barrel (2) which has a machined groove in which Delfrin clips (3) ride and allow it to rotate, locked with a plastic tip set screw not shown.
