For few years I have started a project to build an ultra portable EAA system which is called Astrowl Box. Maybe most of you will discover this system for the first time (if you want to read more about this project there is a topic here : https://www.cloudyni...y-portable-eea/ and you can also find details on www.astrowlbox.com).
In short it is an ultra portable system which onboard everything you need in a small box (camera sensor, 4" display, internal program) that can be inserted in your telescope focuser like an eyepiece and which offers automatic and easy image processing functionnalities like smart telescopes (stacking, frame aligning, light pollution correction, extra image processing filters, ...). The Astrowl Box has its own wifi access point, so you can connect to it to set its parameters (lots of details can be found in the user guide).
The first batches of the Astrowl Boxes were built around a Sony IMX462 sensor (same as Seestar 50) and the last release (still under test) will be around an IMX283 (a big boy).
However after thinking twice I have decided to release a free version of the Astrowl Box and give you all the details and steps to build your own Astrowl Box to democratize EAA.
I made intermediate choices in terms of functionalities and sensor, not that I do not want to offer you the full potential of this box, but if we want to make it easy to build by many people as possible, we must make compromise.
In summary, the sensor will be the IMX477 (not as sensitive as the IMX462, nor as large as the IMX283 which will equip the new Astrowl Box), but you will benefit from an improvement with 2x2 binning which significantly increases its sensitivity . Having tested it on the sky, it is already formidable.
In addition, it is the official Raspberry sensor, so it is inexpensive, easy to obtain. You will be able to keep the basic C-Mount adapter in addition to the EOS-T adaptor which will allow you to install objectives for very large fields
You will benefit from the latest version of Raspberry, the Pi5 which is significantly faster than the Pi4.
There won't be the hardware part for ST4 guiding that is also present on commercial release of Astrowl Box (maybe we will see how to add it to the free version on a future step), because this requires manufacturing the electronic card yourself, therefore not accessible to everyone.
There you go, I hope that you will be interested and you will make your own Astrowl Box and that a community will be able to form to share on the subject.
You will find everything you need to make your own Astrowl Box via the following link:
https://www.astrowlbox.com
A guide which details the creation of the Astrowl Box, the files to print the box in 3D, the Astrowl program and the user manual. Don't be afraid, this is really easy to build.
Please feel free to ask your questions in this discussion thread.
Edited by osbourne one-nil, 31 July 2024 - 03:53 AM.
