Review: The AM3 Harmonic Drive Mount and TC40 Tripod from ZWO
#1
Posted 01 August 2024 - 05:07 AM
Click here to view the article
- cmas likes this
#2
Posted 01 August 2024 - 10:59 AM
If its louder than ioptron mount then i wouldnt recommend this in populated area.
#3
Posted 02 August 2024 - 04:18 AM
Great review! I purchased the AM3 with tripod for many of the reasons you noted. Total weight of the mount w/tripod vs total weight of a similar EQ mount head, tripod, counterweight bar and weights. Ease of setup for me is a thing also. I used to live in Colorado and during the winter, the weight and freezing to the touch weights and bar, time to get balance - all factors which detracted from enjoyment of the hobby. The tracking is very good, ease of use, portability.. all big pluses.
#4
Posted 02 August 2024 - 08:13 AM
#5
Posted 03 August 2024 - 03:07 PM
Thanks a bunch for doing this review! Excellent coverage answered all the questions I had (and more) as I'm shopping for a new mount/tripod now. This (or the AM5) and the carbon fiber tripod are at the top of my list now.
#6
Posted 06 August 2024 - 08:48 PM
I would think that plus or minus 15 or 20 arcseconds (so 30 to 40 arcseconds) is pretty significant for astrophotography. You would definitely need an auto-guider for mid range focal lengths. Or you would need to stack short exposures.
- Brian Carter and prostcj like this
#7
Posted 08 August 2024 - 01:16 PM
Agreed, Harmonic drive mounts have a lot going for them but periodic error isn't one of them. Guiding will of course correct that but if you want to do unguided exposures, a decent, old tech mount might still be the way to go.
#8
Posted 08 August 2024 - 01:31 PM
Interesting experience. My AM3 guides within 0.5 and 1.10 arc seconds.
- danieldh206 likes this
#9
Posted 11 August 2024 - 04:06 AM
In terms of overall cost, using a ZWO guide scope and 120 camera seems like an insignificant addition. Both my AM3 and AM5 are guided. As Rick said above, the performance is good and just about any exposure length I need works out fine. Of course, I just use simple ASIAIR boxes on each without NINA. So, if I don't move the tripods, I just pull the Telegizmo covers off, check alignment in the routine, calibrate the guiding (about five minutes) and tell the autofocus to do it's thing. (Filter swaps do require a refocus).
I still own an old CGEM II, but it is getting fired up less and less. As the reviewer notes, Astronomics ships anything I order right away and even answers their telephone. I sure appreciate a real human answering the phone these days.
- Celerondon likes this
#10
Posted 15 August 2024 - 06:49 PM
It's whisper quiet.
- Celerondon, licho52 and ronrrm like this
#11
Posted 16 August 2024 - 04:24 PM
AM3's big brother AM5 was a christmas gift for my wife (DSO) to replace her EQ6R-Pro which she struggled with when it came to portability. she loves to drive out to dark skies and setup and the EQ6R was a beast for her to use that way. The first amazing thing about this mount (AM5) is how light it is - and the AM3 is even lighter! it changes what you can expect from a travel rig. No longer did she have to choose between lightweight/portable and a desired degree of stability. these mounts break down and pack into a tiny carry case that fits in any trunk, what is not to love about that?
the only problem was finding time to learn how to use it. My wife was so swamped with work, she asked for me to learn how to use it for her as her (spring) birthday gift, and after doing so, i bought one for myself.
i have to say the learning curve was very straightforward and intuitive, even when not using an ASI air. I am mainly into solar, and the ASI air is worthless for me, so i am giving you a 100% "app-based" user experience. I watched maybe 3 youtube videos a half dozen times each while using the iphone app to move it around in the living room before taking it outside. as a solar user, i have NEVER polar aligned this mount and it never mattered. i get a 98% blind alignment easily with the polar align pro iphone app and tell the asi app to drive to the sun. then it's just a matter of a E/W tweak to center it and it's off to the races.
we took it out on the road and used it for the 2024 TSE with a little Bio-Lite power center. in less than 2 minutes, i had the tripod level and i was able to get the mount head blind polar aligned on a cloudy day with an iphone on the saddle. Once the clouds parted, it was just a nudge from dead-center. It tracked like an absolute champ. I can't say enough good things about it.
the AM3 sounds just as good as the AM5, just targeted at smaller scopes with BT as an option, which i think would be a little better than local wifi, but not enough to make a difference in my satisfaction. the only mount that competes with it for my attention is a road-warrior of a skywatcher solarquest, but it can't handle the payload of the AM5. These mounts are probably the best money i have ever spent on the hobby.
#12
Posted 04 September 2024 - 06:00 AM
Great review. I agree completely that visual isn't precluded with these mounts, but there are some downsides to warn about. I'm an AM3/AM5 owner, who has considered this use case but, tellingly, hasn't gotten round to doing ANY visual since switching from an EQ6 two years ago.
1. Without clutches you're completely dependent on power. When the battery runs out you can't carry on with low and medium powers and 'push' RA. That's a pity because I like to do visual when the air is steadiest, just before dawn, and the scope is cooled right down and I'm done with taking pictures - that's usually when my Celestron PowerTank has drained.
2. There is no traditional polar scope, or any other way to get a good PA without having a camera attached. So unless (like me) you have the gear to support photo-visual (e.g. ASIair guidescope and main camera), and you used that earlier in the night, then you probably won't be able to enjoy pinpoint goto.
A 'ballpark' PA by squinting up the RA axis and/or using a GPS compass will likely get you +/- 30". Its a small point but for a premium price, you do want premium performance, and this is a disappointment you might want to mitigate in some way. That generally means throwing more money at the issue (of course you could drift align but how many of us are well practised in that these days?)
3. In this same line of discussion, indirectly related to AM3, but important for visual, IF you do have a telescope optimized for photography that you want to use visually once in a while at the end of the night, beware the auto focusser 'gotcha'. You'll need one that can be disconnected, or one with a hand controller for visual.
4. Unless you have a newtonian the TC40 even with pillar will be too low for comfort. I'd rather not have to use a diagonal or a stool. I put my main visual instrument (130 ED APO / AM5) back on the EQ6 tripod.
These considerations all have an influence on spontaniety and making best use of the weather, as the workflow and setup and the equipment you carry become more complex and need pre-planning. Forgotten items become single points of failure. To respond to that, I love soft luggage and a pre-packed camping cart for my big rig to keep everything in its place and ready to go. The grab and go I just keep assembled on the TC40 for photography only.
All this said I have zero regrets about my AM5/AM3 purchases. Love this gear (and miss my EQ6 a bit too).
#13
Posted 06 September 2024 - 09:46 AM
I have an AM5 and have used it close to the capacity without a CW. My experience in various locations under varied seeing and usually under Bortle 4-6 has been an expected RMS of 0.5-0.7 for DSO guided exposures (3-8min on average) using PHD2. This is acceptable given the image scale (FL < 600) for this rig tends to be > 1. I previously owned an EQ6R-pro which as expected performed slightly better. Unfortunately, you can't air travel with the EQ6. I'd be interested in others experience with the AM5, particularly with higher payloads.
#14
Posted 25 December 2024 - 12:38 AM
I have been using the AM5N mount, PE200 Pier Extension and the TC40 Tripod. I found the pier extension to be a welcome addition as it gets the tripod legs out of the way of any possible impacts with the OTA and equipment. It also makes PA easier as the adjustment knobs are higher up and my old spine doesn't have to bend as much. It does double duty imaging with either a RedCat 51 or an Edge HD8. I routinely shoot 300s subs and once I figured out the settings for guiding, I get 0.6-0.8 Total RMS with the RedCat using a 30F4 / 120MM Mini. I get slightly better numbers with the Edge HD8 using an Askar OAG / 174MM Mini combination with a 0.7 Reducer. Both shoot with the ASI533MC Pro.
I bought this mount because my AVX couldn't balance or guide well with the weight of the Edge as configured above, plus needing to add a 3-pound weight under the Aperture (bringing the total weight of the Rig to 21 pounds) and the 29 pounds of counterweights. With the AM5, I don't need the 3-pound weight, and it really doesn't need the 5 Kg counterweight, even though I do use one with the Edge for stability.
With the RedCat, it's nice to be able to carry the whole thing (Mount, Pier Extension, Tripod and OTA) outside with little effort, just point it North, and start it up. This is especially well received as I hit 60 years of age.
Overall, it's the best thing I could have purchased to make AP more enjoyable.
Edited by Dumanyu2, 25 December 2024 - 10:44 PM.
- timmywampus likes this
#15
Posted 16 January 2025 - 11:58 PM
I have the AM 5 mount and you can hardly hear it when moving if you are standing right beside it. In fact, in the dark you need to be careful that the scope doesn't bump into you when slewing, it's that quiet.
#16
Posted 11 April 2025 - 01:42 PM
I have a question. I am new to the AM3 mount. I bought a pier extension. This would seem to help avoid the end of the telescope hitting the tripod legs. However, I have a concern. Though the end of the telescope is above the tripod, it is still physically possible for it to hit the pier at some angles. In tracking or goto modes, does the mount know not to go to such angles that would cause it to strike the pier?
#17
Posted 11 April 2025 - 05:08 PM
Depends. If you have a filter wheel for example then if it is not oriented at a 90 deg angle then it will slam into the pier when approaching the meridian. And that also depends on how long the scope is as well. Short answer though is a pier extension will definitely help.
Edited by hyiger, 11 April 2025 - 05:08 PM.
#18
Posted 13 April 2025 - 08:47 AM
No, a pier is usually insufficient by itself of some telescopes. I have a 5" refractor on an AM5 with a pier extension, and it doesn't prevent the camera from hitting the tripod legs. You can program some limits into your software, creating a black hole in the sky your scope won't point to.
Another solution is to add some riser blocks to your tube rings/dovetail (see link below). This raises your telescope an inch above the dovetail plate, and will provide you with some additional clearance.
https://agenaastro.c...ks-spacers.html
