over the weekend, a friend showed me his C6. the secondary mirror freely rotates in the secondary mirror holder. I did some search and it appears that there is indeed some issue with sometimes secondary mirror housing getting lose.
The posts also say the etching/notch on the secondary mirror holder should point to 3 O'clock assuming the dovetail is pointing towards the ground.
I checked some pics online and the attached shows the front view of C6 from celestron website. While our C6 isnt same (it came with evo - silver tube), when I point the dovetail to the ground, it does look the same.
I would like to confirm that the secondary mirror etching/notch is indeed at 3 o'clock (opposite to focuser which is at 9 O'clock) before I take out corrector plate and tighten the secondary holder.
I think that's wrong.
For an OTA from an Evo or SE, the alignment pin should be on the same side as the dovetail. So six o'clock in your picture.
When mounted, the serial number should be read upright. Not sideways.
But I don't know if the secondary rotation is critical or not.
I have always read that the corrector plate should be kept at a certain rotation though.
Edit:
But maybe there is a huge misinterpretation.
You say the secondary freely rotates in the secondary mirror holder.
But that's impossible, because there is an alignment pin on the secondary and a groove in the secondary holder.
I can only guess that what you are calling the secondary mirror holder is not the secondary mirror holder, but actually the corrector plate. The glass lens.
And the corrector plate does need to be correctly positioned. As it is rotated for best correction from the factory.
Is the "secondary mirror etching/notch" that you refer to a mark on the glass? Or the notch in the secondary housing?
Edited by Echolight, 04 August 2024 - 01:03 AM.
