Hi!
First I apologize if I'm in the wrong place.
I want to astromod my canon 850D(T8i) but i have a few questions.
Can i have a astronomik glass with LFP1 filter together? If yes, i will need to reajust the sensor?
My friend warned me to not use baader cause they suck and use astronomik instead
If i just remove the LFP2 filter, can i still use my lens?
In the future i will use my canon with a refractor telescope and a rikinon 135mm, but for now i just have kit lens like 18-55mm and the 75-300mm.
And i still want to have AF, the auto cleaning sensor and day photography with a custom WB
Thank you for your time!
Using various internet resources, I successfully astro-modded my Canon 60D a couple of years ago.
In my case I only removed the LFP2(?) filter, did not add anything back in. People will tell you that this will mess up your AF, however there is a simple workaround (if your sensor mounts the same as mine did)
The sensor is mounted by three sprung screws so it can be adjusted by a technician individually to calibrate the autofocus. Since you are removing a known thickness of glass, it is possible to compensate by resetting the sensor to a slightly different position. Most important is to make a very careful measure of the current sensor "height" and when finishing up, adjust those screws to a position 1/3 of the thickness of the glass that was removed (sorry - don't remember).
After reassembly, sensor cleaning and my autofocus worked perfectly (confirmed with two different lenses). As you mentioned, a custom WB can virtually restore terrestrial shooting.
You need to close yourself off without disturbance in a very dust free location for maybe 2-4 hours and don't rush things.
