I picked up a hyperstar 4 cutout version of the astrozap, which to me almost doesnt "feel" like aluminum, has felt on the inside and a hard time even getting it flush with the dove tail on the scope top and bottom.
The issue is my nexdome shutter module would strike the end of it if it was in a bad position or in the way. The old dew shield i used was the celestron flex shield which i did cut, its probably 3" shorter measuring to the dove tail to the end of the shield and was always "safe" in the dome.
I tried sliding the scope back on the saddle on the cem120 mount, but now its so back heavy i dont have enough weight in the front and feels crazy to buy more heavier weights for my weight holder that hangs (barely in the rear position) in the front, so i've slid the scope mostly back to where i had it for now. Honestly if i slid it back even further it may clear but then there would be no way to add weight to the front of the scope. The f7 oag setup is quite heavy and weighs the rear down alot.
I opted for trying the aluminum because i wanted something that was less warped and something i could put a real cap on the end of it when not in use. The celestron aluminum one was even longer, so i had hoped this wasnt much of an issue since it was shorter.
So im thinking of cutting deeper notches about 2.5 to 3" further
So im thinking of cutting deeper notches about 2.5 to 3" further inward, so it sits further back, the alternative is making a straight line about 3" from the end, and maybe using a saw to cut it, but im concerned especially at the end for cutting, that the felt on the inside will fray and lead to constant debris.
For just notch extending im thinking these will work:
https://www.amazon.com/dp/B0BMGC5SVP
For the other end cutting the whole way around, maybe a rotary saw like this:
https://www.amazon.c...duct/B09QXBC6XL
Anyone done this with this particular model and can comment on the best way to cut, should i opt to keep it?
**I suppose if a "cap" could be constructed, id live with the flex shield, however i can never get a perfect circle with it, always warped (not sure if that matters).
Thanks in advance
Some photos, the one that shows the gap ended up blurry, i need better shots in the day:
Edited by markm75c, 07 August 2024 - 09:43 PM.
