This image of the Saturn Nebula (NGC 7009) was taken at the prime focus of a Takahashi FC-100DZ fluorite doublet refractor using an uncooled ZWO ASI678MC "planetary" type camera. I combined 448 subs that were each exposed for 4 seconds so the total integration time was 29 minutes and 52 seconds. The capture scale with this setup is 0.52 arc seconds per pixel but I did a 2X drizzle during the processing and then reduced that to 67% and thus the reproduction below has an image scale of 0.39 arc seconds per pixel (probably near to critical sampling for this 4" refractor). The limiting magnitude on this shot is approximately 18 (ASTAP says 18.8) and north is oriented up.
I posted an earlier version of this image with fewer subs and without a drizzle over in "Beginning Deep Sky Imaging" but with the drizzle processing and some PixelMath to neutralize a little background color mottle this version probably needs to go in the "experienced" topic. However, if you want to see what the Saturn Nebula looks like with just over two minutes of total integration time (from a Bortle 7+ site) then you can link to that thread as given above.
I had some problems getting the drizzle integration to work because apparently PixInsight's file cache for ImageIntegration had been corrupted and even though the file list in the process was correct and complete PixInsight wan't using all of the subs during the standard, 1X integration. It did not log any errors during the normal integration but when I went to do the drizzle it reported that some information was missing from the source files (those ended up being the XDRZ files although that was NOT mentioned in the error messages). It took me an hour or more to figure out what was wrong and then I remembered that I'd had similar problems in the past that were fixed by clearing the file caches that are maintained by the integration process (accessible under the "wrench" icon at the bottom of the ImageIntegration process window). So, I reset the file caches (all of them) and redid the image integration and then the XDRZ files were properly undated allowing the drizzle integration to run.,
Image capture with N.I.N.A. using direct "guide" with dither, image processing with PixInsight and Photoshop 2024. There are additional capture details in the image captions. Click on the preview to see the full-sized image.
Edited by james7ca, 10 August 2024 - 12:18 PM.
