OAG-L (ZWO, M48 female) adapter to a non-Edgehd SCT C11?
Celestron SCT Accessories
9 replies to this topic
#1 Nuno Cunha
Nuno Cunha
  • Loc: Esmeraldas - Minas Gerais - Brasil
Posted 10 August 2024 - 08:19 PM
What would be the adapter to connect an OAG-L (ZWO, M48 female) to a non-Edgehd SCT C11 (2")?
Something similar to #93633-A, so I can change the orientation of the camera sensor.
Thanks for the help
#2 KNak
KNak
Posted 10 August 2024 - 08:53 PM
Why not ditch the 2" adapter and use this: https://www.celestro...-9-25-11-and-14
#3 Nuno Cunha
Nuno Cunha
Posted 10 August 2024 - 08:59 PM
Can this be used on a non-EdgeHd?
#4 KNak
KNak
Posted 10 August 2024 - 09:22 PM
Yes it's the same 3.27" end. I have it on my C11 XLT non-Edge
#5 Nuno Cunha
Nuno Cunha
Posted 10 August 2024 - 09:42 PM
It seems that with this one I would have trouble getting focus. Using a focal reducer the OAG-L + filter wheel would throw the camera too far back...
Edited by Nuno Cunha, 10 August 2024 - 09:44 PM.
#6 KNak
KNak
Posted 11 August 2024 - 07:22 AM
You'll always be able to get focus but might not be optically optimal.  I assuming you have the f6.3 reducer?  I have the Starizona large format reducer so the that T-adapter is perfect for my setup.
Another option then is the Blue Fireball large SCT (3.28") to M48 adapter with M48 spacers, or a variable M48 spacer where you can fine tune the backfocus (helical adjustment).  The benefit of this (as opposed to a 2" SCT to M48 adapter) is that the clear aperture of the Celestron SCT adapter you have is only 38mm whereas the Blue Fireball adapter is 44mm.  This can mean less vignetting or better guide stars at edge of FOV for OAG, but this may not be important to you.
#7 Nuno Cunha
Nuno Cunha
Posted 13 August 2024 - 10:35 PM
Yes, an f6.3 focal reducer.
My question is, what if I want to rotate the camera? Adapters like the #93633-A allow you to rotate the camera easily, whereas the ones I've seen, the SCT-M48, do not.
#8 KNak
KNak
Posted 17 August 2024 - 04:00 PM
Yes you're limited in that respect with that OAG. The Hercules OAG I have can rotate both sides of the OAG. You may have to add a manual rotator then if you can afford the backspace (assuming you want to stay with the ZWO OAG)
#9 speedster
speedster
    Vendor - Telescope Piers
  • Loc: Abilene, Texas
Posted 18 August 2024 - 11:45 PM
Add M48 manual rotator for about $60.  https://agenaastro.c...hread-r-05.html
It only uses 13.5mm of back space to probably not an issue with that.
#10 Nuno Cunha
Nuno Cunha
Posted 19 August 2024 - 11:20 PM
Great, something like this.
  I think I need it to be before the focal reducer. It should be similar to the reducer, with a female for the telescope side and a male for the other side (for the reducer to attach to).
  2"? M54? M48? I don't know the thread size of the C11...
ps: found the thread size: 2"-24 TPI, so I need a camera angle rotator with male and female of 2"-24 TPI.
Edited by Nuno Cunha, 20 August 2024 - 12:14 AM.
Also tagged with one or more of these keywords: Celestron, SCT, Accessories
