Awoke at 2 AM local time and felt good enough to try and get Tethys shadow using the 11" f/5.7 Newtonian.
Wow! First look using a 3mm Radian (529x) was stunning. I had barely tweaked collimation on a Jupiter moon yesterday morning before shutting down and I guess it didn't hurt. Anyway, I booted up the laptop and focused in the ZWO224MC and 5x Powermate and captured seven 20K vids (3-4-minutes each). Used 6.8 to 13 ms exposures and gain from 480 to 520 (IIRC). Only spent an hour and went back to bed without even a cursory look since this was my second early get up in a row.
Anyway here are some early results after good sleep using my less than elegant processing skills.
I really pushed the processing but I think I have evidence of Enceladus and its shadow - my processing is probably limiting the data but it appears about right on my planetarium program. If it is, I'd be pretty happy to get this with an 11"!
Sorry for so many images but the seeing was very nice. I again did not see single Perseid (and I did try to look occasionally).
Mike Spooner
UTC 09_12 8-13-24; 50% stack.
UTC 09_15; Probably my best "normal" processing, 50% stack.
UTC 09_21; 30% stack.
UTC 09_24; 15% stack and crops of this image.
