As I said in an earlier post, I did get the rings from Joe Nastasi at Parallax this past week. And along with them, I had to make a decision about the future of this scope-leave a complete restoration as a possibility, or to make it a living, working scope returned to like “new”, but with modern functionality.
The latter is the decision I committed to over the last 48 hours. In order to get the rings on and as far back to the cell as possible, the mount pylon, finder stalk and guidescope rings had to go. Basically had to strip her down to the bare optical tube.
The rings for the guidescope and the finder stalk were easy. And led to the discovery that the tube is DOUBLE wall aluminum. This is new construction methodology to me, but it allowed attachment of accessories to the outer wall without violating the integrity of the inner wall of the OTA. Not sure how the walls are spaced to maintain concentricity, but it sure seemed like a solid wall until I got the rings off.
And it really became clear when I FINALLY got the mount pylon off. Which was a nightmare. The pylon was held to the outer shell with four bolts, but it was then filled with that hard poly foam like is used for home insulation. Those who are familiar with this stuff know it becomes part of an engineered structure, adding significant strength as well as insulating the buildings. Well, it made the pylon almost a permanent part of the optical tube. However, after several hours chipping away at the foam, more than one drop of blood spilled, and a hopeful astronomer nearing total exhaustion, a sudden “POP” and off it came. Hallelujah. All downhill from there, the rail for holding balance weights was also held in place with the same foam fill, along with 4 pairs of dome head screws, but it was easily removed.
Now I have a tube fully bare on the outside, ready for the rings. And I now see how the double walls are stabilized. The space between the walls is filled with this foam. Nice! At least I now know the structure is stable!
Mr. Nastasi’s ring set fits perfectly, and I am really close to setting this monster atop the Losmandy Titan and pointing it towards a planet or two. But the observatory is a few weeks away from being ready. Would anyone short of Andre The Giant consider this thing portable and set it up in their yard? Hmmmmm
Edited by Kitfox, 14 September 2024 - 05:43 PM.
