Lenses cleaning materials
29 replies to this topic
#1 CosminXF
CosminXF
  • Loc: Bucharest, Romania
Posted 15 August 2024 - 12:15 PM
How do I clean the lenses of the APO, other than using the dedicated cleaning kits? What material can be safely used?
#2 Astroman007
Astroman007
  • Loc: Latchford, Northern Ontario, Canada
Posted 15 August 2024 - 01:02 PM
Pure isopropyl alcohol on soft cotton swabs, very light touch. Soft "camel hair" brush for removal of any dust from optical surfaces beforehand.
#3 C. Evangelista
C. Evangelista
  • Loc: Heidelberg/Germany
Posted 15 August 2024 - 02:54 PM
I can recommend this product, after careful and complete removal of dust or dirt by a soft brush:
https://www.baader-p...ning-fluid.html
  • Marcus Roman and j.gardavsky like this
#4 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California 38*N., 122*W.
Posted 15 August 2024 - 06:33 PM
ROR (residual oil remover) works real well for a streak free result borg.gif
https://www.amazon.c...,aps,605&sr=8-1.
Edited by sevenofnine, 16 August 2024 - 12:48 PM.
  • Skywatchr and Marcus Roman like this
#5 PeterWar
PeterWar
  • Loc: Roses, Girona (Spain)
Posted 15 August 2024 - 07:11 PM
Get this and don't look back, there is no better cleaner for APO lenses.
https://www.edmundop...F8aAng4EALw_wcB
  • Skywatchr, AZStarGuy and denis0007dl like this
#6 Michael Covington
Michael Covington
    Author
  • Freeware Developers
  • Loc: Athens, Georgia, USA
Posted 15 August 2024 - 07:41 PM
Do I recall correctly that some lens cleaners, including ROR and Eclipse, have a limited shelf life and should not be used if old?
  • Skywatchr and denis0007dl like this
#7 PKDfan
PKDfan
  • Loc: Edmonton
Posted 15 August 2024 - 10:06 PM
Hi Michael !!
I looked at my ten year old ROR and see no expiry date but haven't used it for awhile now but i'm prepping my 100ED lense for its first cleaning, getting my distilled water & isopropo alchohol plus refined petroleum ready plus Q-tips and cotton balls.
So will see if problems occur but as i remember last time i used it the streaks needed some extra effort to fully eradicate.
A curious experiment for sure !!
Clearest streak-free Skies
Lance
Edited by PKDfan, 15 August 2024 - 10:07 PM.
  • Michael Covington likes this
#8 Skywatchr
Skywatchr
  • Loc: North-Central Pa.
Posted 16 August 2024 - 06:29 AM
Click on the "resources" tab for tips on cleaning optics of all kinds. waytogo.gif
#9 Skywatchr
Skywatchr
Posted 16 August 2024 - 06:35 AM
As long as the cap was put on tight, it should still work fine.  I see no "expiration date" on mine anywhere.  But with that said, nearly everything has an unopened shelf life.  Depending on how old, it may not evaporate as quickly as when brand spanking new.
Keep in mind, RoR is an oil remover for (mainly) fingerprints, eyelash and skin oils.  It's the last step after removing all other "dirt".
#10 Wildetelescope
Wildetelescope
  • Loc: Maryland
Posted 16 August 2024 - 07:50 AM
Purosol enzymatic cleaner works well on sap and other organic contaminates. Recommended by AP.
Jmd
  • Skywatchr likes this
#11 briansalomon1
briansalomon1
  • Loc: Oxnard CA
Posted 17 August 2024 - 07:44 AM
At Litton/Northrop Grumman we used compressed N2 (at home I use a bulb blower instead on N2) to blow off any particles, followed with a cotton Q-tip with a single drop of 90% or better isopropyl alcohol on the Q-tip. Larger lenses can use 5 or 6 Q-tips held in a bunch.
Start in the center and work outwards in a circular motion. How quickly the solvent dries affects the result, so practice. I will sometimes use 3 Q-tips and have solvent on only one of them. By rotating the dry Q-tips onto the lens while I clean, you can prevent streaking. Use a bulb blower to remove any cotton particles.
Acetone is a stronger solvent and safe to use with Q-tips on lenses/mirrors. Acetone leaves a film and should be followed with isopropyl alcohol. For cleaning optics at home, I consider all solvents labelled "isopropyl alcohol" and "acetone" the same (you don't need reagent grade)
This matches pretty closely with what they teach in USAF and aerospace optics courses https://www.televue....page.asp?id=103
  • Astroman007 and Northern Jeff like this
#12 PeterWar
PeterWar
Posted 17 August 2024 - 12:46 PM
Jmd
Recommended by Takahashi as well. Can't go wrong with it, I've cleaned all sorts of optics at the observatory.
  • weis14 and j.gardavsky like this
#13 LDW47
LDW47
  • Loc: North Bay,Northern Ontario,Canada
Posted 18 August 2024 - 07:40 AM
Clean spit and the soft clean pad of your index finger, two of the most neutral materials in the world, the enzymes in clean spit can't be compared, for cleaning.  World renowned for those that know, every time and then a soft kleenex to dry it off, its unchallenged in this challenged world, eh.
  • j.gardavsky likes this
#14 Astroman007
Astroman007
Posted 18 August 2024 - 01:25 PM
I wouldn't use spit on any of my stuff...
#15 LDW47
LDW47
Posted 18 August 2024 - 05:30 PM
Thats up to you.
#16 Retentive
Retentive
  • Loc: Florida
Posted 19 August 2024 - 06:22 AM
If I had a dog, I would try letting it lick the lens, see how that works.
#17 weis14
weis14
  • Loc: Midland, MI
Posted 31 August 2024 - 09:09 PM
Just cleaned my Stowaway this evening after a rough session with a lot of dew and pollen a few days ago.  Used blower, brush, Purasol and 91%IPA in that order with lint free wipes.  Per Astro-Physics' long standing instructions, I used saliva on one tough pollen spot, but it needed a couple of passes with IPA after before being free enough of streaks for my taste.
The hardest thing is to remember to quit before you think you are done and not overdo it.  My goal any time I touch the lens is to get it only 90% better.  The last few small streaks or spots won't affect the image at the eyepiece or the condition of the lens long term.
#18 LDW47
LDW47
Posted 31 August 2024 - 09:18 PM
You probably didn't use enough spit and then a soft cloth, keep at it practice makes perfect. Also did you rub it around with the soft, clean pad of your index finger. I learned that years ago from an Opthomologist friend of mine and confirmed by my Optometrist. The pads of ones fingers is considered to be one of the softest materials in the world, provided of course they are clean.
#19 sw196060
sw196060
Posted 12 September 2024 - 08:41 AM
What do folks recommend for cotton swabs for cleaning the lens?  I can use qtips as well.
I worry about anything leaving lint behind.
#20 peleuba
peleuba
    Non-Metrologist
Posted 12 September 2024 - 09:47 AM
Its fairly well known among refractor buffs that spit works very well for stubborn spots on lenses.  It works.  Really.
See here and here from Roland Christen.
Edited by peleuba, 12 September 2024 - 11:28 AM.
  • dawnpatrol and LDW47 like this
#21 Rusty35
Rusty35
Posted 12 September 2024 - 10:36 AM
Where would one purchase "clean" spit? Mine always has coffee in it !
  • peleuba and aneeg like this
#22 LDW47
LDW47
Posted 12 September 2024 - 11:12 AM
I guess you are Sh.. out of luck, lol, I guess !
#23 LDW47
LDW47
Posted 12 September 2024 - 11:15 AM
Afterwards you just blow any lint / fuzz off with a blower bulb, pretty simple.  Every one should have an air blower handy and ready, eh.
#24 sw196060
sw196060
Posted 13 September 2024 - 07:31 AM
I have one of those Jet bulb blowers.  It comes in handy.  Still, I like to minimize the lint to begin with.
I just checked my small bottle of ROR and it had an expiration date of 2016 on it.  Doh !!
I ordered a new bottle right away.
  • dawnpatrol likes this
#25 Michael Covington
Michael Covington
    Author
Posted 13 September 2024 - 08:49 AM
What happens to ROR (and also "Eclipse") when they get old?  I'm concerned about the expiration dates myself.
