Western Veil
#1
Posted 15 August 2024 - 12:16 PM
- revans, Jim Waters, mikewayne3 and 9 others like this
#2
Posted 15 August 2024 - 12:25 PM
best picture i've seen from you dan
- Tkall, Zambiadarkskies and DanMiller like this
#3
Posted 15 August 2024 - 12:41 PM
Thank you. I do think the uv/ir filter, even if it was only 22 dollars helped my stars. And I FINALLY got really close to what I wanted from my auto focus. Strange, I just doubled my backlash on it. Probably both changes helped improve things.
This was also the first image I posted with the new camera where I had the all correct calibration files. I know, sounds stupid. But everything was correct finally. Gain, Offset, exposure time, rotation, flats.
There are a couple lessons learned with this image. I am going to have to stay with shorter exposure times. These were only 60s. But my mount just isn't good enough to do real long exposures with the sensor on the camera. Thats fine, I am now able to stack with sirill. Actually might restack this iwth WBPP. Thinking about it. Never know, might throw it on before I go to bed.
Again, thank you.
Dan
#4
Posted 15 August 2024 - 01:34 PM
Nice image and processing Dan.
#5
Posted 15 August 2024 - 04:50 PM
As an update, because I have a book going that will probably keep me occupied the rest of the night. I decided to process the data through wbpp this time. The 8.7 hours are before rejects, not after. I'm really courious to see how much data really is there after rejects.
Just courious to see the results.
Dan
#6
Posted 16 August 2024 - 08:09 PM
Second image, WBPP stacked with registration and intigration done on each channel then combined in post edit with pixinsight. The stars are from the origional sirill stack
I'm not sure why the colors are different. Seperat registration and intigration on the channels brings out more blue? I do like the stars better though out of the sirill stack. I just think they look better then what wbpp gives me.
All though, you can see that the stars are in different places. The combination of the stars from the two different software stacks stands out with placement of the stars. Interesting. I'll stick with liking the sirill stack better.
Hmm, I wonder if I it has to do with wbpp cropped and I bet that the sirill stack didn't. Wonder if I should have cropped down the stars of the sirill stack to be the same size as the wbpp stack. Have to think on this.
It's fun to play. Sorry
Dan
Edited by DanMiller, 16 August 2024 - 08:36 PM.
- mikewayne3 likes this
