Thanks for the shout-out, Michael. It was fun hosting you at the Ashokan site.
I was looking at the LP map and the central/western Catskills have an area that's B3 around Andes, Bovina, and Pepacton Reservoir. Is anyone familiar enough with that area to recommend any good viewing sites? Either public lands (DEP land, parks, etc. that are not closed at night), or private where I can get permission to drop by any time. Maybe somewhere along NY 30 along the shore of the Reservoir, though that appears to be pretty much forested (Shavertown Trailhead to a large clearing?). A short schelp (up to 1000 feet or so) from the car is OK. I'm around B4 to B4.5 at my home site, and the Ashokan site is about as good -- maybe a little bit of light dome from Kingston and Poughkeepsie (and points further south) that I'm someone shielded from at home, though at the cost of a somewhat high southern horizon.
Though it's shown as a bit into the B4 zone, NY 30 in Halcottsville between Margaretville and Roxbury has a scenic parking area that sounds promising. There might not be much of a view to the east, but I might drop by to take a look anyway. All this is further than Michael is planning to drive, but it might be feasible for me. The biggest problem is that none of this (Shavertown or Halcottsville) will be plowed in the winter, and is rural enough that I will need to worry about black bears showing up.
If anyone is familiar with viewing sites in this area, please chime in!
Hey, Phil, thanks for your help!
If you're referring to the color coding on the maps I prepared, they're based on the Light Pollution Atlas 2022 by David Lorenz. I spoke to David when I first started this project, and to be fair, he doesn't like the Bortle Scale and is uncomfortable with translating back and forth. That said, his colors translate to SQM, and there are SQM ranges associated with the Bortle Scale.
If you read the overview document, I provide a conversion scale between the map colors and Bortle based on Wikipedia's SQM levels for each Bortle level. Bottom line, the blue area on the map corresponds to the top half of Bortle 2 SQM levels. All of the forest green and about 2/3 or the kelly green areas correspond to Bortle 3 SQM. And Bortle 4 ends right about at the border between the light olive green and mustard yellow.
Again, take it with a grain of salt (YMMV). Ashokan is located in the Kelly Green, an area that converts to Bortle 3 or 4... Yes it has some pretty serious light domes, but they turn pretty dark above 15° elevation, even looking towards Poughkeepsie/NYC. In most sites, those domes would be hidden behind trees or other obstructions.
My back yard is in the olive green, i.e. Bortle 4. I usually see the Milky Way, but with much less complexity than at the Ashokan Reservoir looking high in the sky. On that comparison, I'm comfortable calling Ashokan Bortle 3. My back yard doesn't have light domes to speak of, but most of the sky below 20° elevation is blocked by trees anyway.
The day we were there I was imaging M6 and M7 successfully at 10° -- I was VERY pleased.
