Why remove baffles of Classic Refractors.
36 replies to this topic
#26 deSitter
deSitter
    Still in Old School
Posted 01 September 2024 - 09:09 AM
Great info, thanks again.
I found the 'deepest one' best inserted lens side first (put in approximate position). Was using an old fishing rod protector tube to reposition!
L.
I use a baseball bat to move tube baffles :)
-drl
  • T1R2 likes this
#27 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 01 September 2024 - 11:59 AM
At last! That explains all those dented tubes!
Chip W.
#28 T1R2
T1R2
  • Loc: Little Rock, Arkansas
Posted 01 September 2024 - 02:10 PM
-drl
I use the SCH80 PVC pipe and a mallet
#29 rolo
rolo
  • Loc: GA
Posted 01 September 2024 - 09:23 PM
None of my TeleVues had any baffles, not necessary and if incorrectly spaced they will block the FOV & effective aperture.
#30 Oldfracguy
Oldfracguy
  • Loc: San Diego, CA
Posted 01 September 2024 - 09:57 PM
Sometimes the main tube baffles are right, sometimes they are wrong, usually when you hear of us knocking out baffles its the ones in the drawtube, but we usually go for both to make them perfect. going from .965 to 1.25" accessories, the smaller aperture baffles in the drawtube for the 965 will not allow full illumination of the 1.25 diagonal, sometimes its quite noticeable vignetting.
I tried moving the single baffle in my 54-year-old Mayflowe 814 60mm f/11.67 achromat to get a little more light through after having converted the visual back to accept either a 1.25" Diagonal or a Baader T2 Prism Diagonal:
Man, was that a mistake!  What I was unaware of was the the baffle was placed far enough forward in the tube to mask the irregularites in the objective.  I decided I would much prefer a sharp, crisp view with a decent star test pattern with effectively a 50mm scope perhaps than a bloated, astigmatic view with the full aperture and the baffle moved farther back in the tube to where my calculations indicate it would pass the full light cone required for a larger 1.25" diagonal.
  • T1R2 and Princess Leah like this
#31 deSitter
deSitter
    Still in Old School
Posted 01 September 2024 - 11:29 PM
I would not give up on that. A 50mm objective is small enough that, combined with cell slop, the elements can decenter relative to each other. I have a 50/600mm Towa, Monolux 4348, which at first did not give great performance. I kept shaking the assembly until the lenses settled into the right orientation, then tightened down the retaining ring enough to hold them in place. It can easily do 100x, 50x per inch.
-drl
  • Oldfracguy and Princess Leah like this
#32 Oldfracguy
Oldfracguy
Posted 02 September 2024 - 12:04 AM
-drl
I used a narrow wiffle ball bat!
  • Princess Leah likes this
#33 Princess Leah
Princess Leah
Posted 02 September 2024 - 03:52 AM
Would be interesting to see if adding a few temporary baffles would improve this already excellent scope.
#34 Princess Leah
Princess Leah
Posted 02 September 2024 - 03:56 AM
That Pronto see a lot of use David smile.gif I tried one recently and was impressed (despite the axis position).
Can you comfortably use it near the zenith and does it come with shorter slow mo controls?
Edited by Princess Leah, 02 September 2024 - 03:59 AM.
#35 Oldfracguy
Oldfracguy
Posted 02 September 2024 - 09:33 AM
You can probably purchase shorter slow motion control handles, or make them yourself.  The shafts that extend outward on either side from the Altitude and Azimuth position control gears are 6 mm in diameter.  I made some a couple years ago for an Explore Scientific Twilight I mount out of threaded rod (5/16" I believe) I bought at a local hardware store and a 5/16" coupling nut.  The existing round plastic knobs from the original long control handles were a perfect fit.  I drilled and tapped a hole near the end of each coupling nut in order to secure it onto the 6 mm shaft.  Of course, there was a little slack, so I wrapped the shaft with a few turns of duct tape to enlage its diameter.  It actually worked quite well:
And yes, with the SW AZ Pronto Alt-Az mount you can position a scope not only directly at the Zenith, but even a bit past it:
Edited by Oldfracguy, 02 September 2024 - 04:13 PM.
  • Kasmos and Princess Leah like this
#36 rolo
rolo
  • Loc: GA
Posted 02 September 2024 - 01:10 PM
#37 Princess Leah
Princess Leah
Posted 02 September 2024 - 03:46 PM
Wouldn't count on that.
