I'm posting this in hopes of positive advise and help to find a solution to adapt 60mm/2.36" male threaded OD, 54mm non-threaded ID rear cell on what I think is a 1990's Celestron C14 SCT, to the common 2"/M48 thread on all or most SCT accessories.
I bought this used "black tube" C14 the beginning of August. I have it mounted to a used AP1200GTO I also purchased around the same time. The equipment is all attached to a concrete pier in my back yard roll off roof shed.
So, the info on this scope is it's a 14" Celestron SCT with "Celestron" printed in orange on both sides of the black tube. On the top of the tube, there is one sticker that says "StarBright coatings" with no mention of XLT. There is another sticker the says "Fastar Compatible". The optics appear to be in very good condition.
The issue is on the back of tube there is ribbed sandcast metal with the rear cell tube protruding very slightly. I do not know tpi, but the OD measures 60mm at the top of the threads. The ID of rear cell is something like 54.7mm, but my caliper is a cheap digital one, so it's probably just 54mm id. There is nothing else on the back around the 60mm rear cell.
The scope came with a Lumicon Giant Easy Guider (with missing OAG tube, but an intact 80mm "corrector" mounted in metal frame and, and adapter ring with female threaded 60mm ID an OD of 91mm. The outer surface of the ring is grooved and is fixed to the giant easy guider by 3 brass tension screws that secure the guider to the adapter ring. I can mount my ASI294MC Pro camera to the easy guider, but I'd like more flexibility to connect a ZWO EAF controlled 2" GSO linear bearing focuser, a coma corrector/reducer, ASI camera, filters etc.
I contacted Agena-Astro and all they could say is it looked as is maybe a piece was missing and to contact Celestron.
I had already contacted Celestron and am awaiting feedback from them.
I contacted High Point Scientific and am awaiting feedback from them.
Here is all relevant dimensions
rear cell of C14 = 60mm OD threaded, 54mm ID unthreaded
Giant Easy Guider = 91mm ID unthreaded, 100mm OD unthreaded
Giant Easy Guider to rear cell adapter ring = 60mm ID threaded, 91mm OD grooved
GSO 2" linear bearing focuser = Main assembly 73mm ID unthreaded, SCT adapter ring 73mm OD unthreaded, SCT adapter ring ID 50mm threaded ** The SCT adapter ring screws onto a 50mm rear cell and tension screws clamp the main assembly onto outer part of the SCT adapter ring. Item is shown here - https://agenaastro.c...dual-speed.html
I'll attach pictures that show what I'm trying to explain here.
Hopefully this post is in the right category.
Thanks in advance for any info you can provide.
Ralph
