Months ago I purchased a older Celestron FirstScope and now I am noticing it is a bit hard to keep in accurate collimation.
Why you say? One reason is a very slight focuser drawtube wobble. The focuser feels fine when using it but it's very hard to keep in alignment. Is there a way to adjust it? Or rebuild it? Or is it normal? Just replace it? It seems I have many things that I want to do to this scope to make it better. I guess that's what happens when you purchase used merchandise. Oh its a 4.5 inch x 900mm scope if that matters. celfocB.jpg
The 2 screws on the back of the focuser press the pinion gear into contact with the rack on the drawtube.
Tightening the screws will reduce the slop, but will also make the knobs harder to turn, so there is a fine line between tight enough and too tight.
And if the drawtube is plastic instead of metal, tightening the pinion gear will crack the teeth on the rack. So be sure it's metal before you tighten the screws.
Inside the focuser (accessible from the bottom, there should be a couple plastic slides the drawtube moves up and down on. The pinion gear presses the drawtube against them.
They might have shifted or gotten lost, so look in to see that the focuser is sliding on the slides inside the focuser body.
