wide field ep suggestions
Started by
Guest_**DONOTDELETE**_*
, Jun 23 2004 02:57 PM
7 replies to this topic
#1
Posted 23 June 2004 - 02:57 PM
Greetings,
I am looking for suggestions on a wide field EP, not very expensive, I can't afford TV Naglers/Pans/Radian etc.
I use a 102mm f6.9 refracter from light polluted mag 4 skies in North Carolina.
I was looking at 24mm to 32mm wide field EP's, this would give me somewhere between 22 and 29X. I just have never had
an wide field eyepiece so I ha no experience with them.
If the experienced observers here have any suggestions I
would be grateful for them.
#2
Posted 23 June 2004 - 02:58 PM
At f6.9, check out the thread on the GSO widefields in this forum.
Jarad
Jarad
#3
Posted 23 June 2004 - 03:09 PM
I have Siebert Optics Observatory 24mm and 36mm 80 degree eye pieces and think their pretty great, at least they hit close to the PanOptic level of performance. Not the Nagler level of performance though.
#4
Posted 23 June 2004 - 03:28 PM
I observe in mag 4.5 skies. I find that the background is pretty washed out when using my 25mm plossl at 30x. I recently bought a 19mm Antares W70 that gives me the same TFOV as the 25mm plossl but at 40x which makes the background a little darker. It works pretty well in my f6 scope. I use it as my finder eyepiece now. You can also get a 25mm W70 which I know several people here really like. ScopeStuff has the 19mm for about $50 new and the 25mm for $80. I bought the 19mm off AstroMart for under $40. Other options would be the 2" GSO SuperViews Jarad mentioned and UO Konigs in both 2" and 1.25" format.
#5
Posted 23 June 2004 - 04:01 PM
Bmolles,
Welcome to CN! If you're in the Concord,NC that's down near Charlotte, you might want to get together with some of these folks Charlotte Astro Club You could probably find some of them that would let you try out various eyepieces in your scope.
Are you looking for a 2" ep. or a 1.25"? In 2", I'm pretty happy with a $69 Burgess 32mm. In 1.25" the Ultimas get consistantly good reviews.
Mike Swaim
Mike Swaim
#6
Posted 23 June 2004 - 09:14 PM
I love my 30mm Ultima. Digitec Optical sells them for about $93, a few bucks cheaper than most and I've heard nothing but good about their service.
#7
Posted 23 June 2004 - 09:29 PM
A good choice might be a Meade Super Wide Angle 24.5mm, with the widest field possible in a 1-1/4" eyepiece. These go for around $150, though, so the GSO/GTO/Astrola/etc wide angle eyepieces under $100 might be an alternative.
Frankly, a good 50 degree AFOV might be enough at low power, but here's how to look at it: as the power increases, the background gets darker because the sky brightness is distributed over a large area. This makes a 24.5 wide angle better than a 32mm Plossl. Though both give the same field of view, the 24.5 will have a darker field and better contrast. So, higher power with the same field of view will yield better contrast. This is the primary reason wide field eyepieces make such good low-power eyepieces.
In 2" the same thing occurs, but at longer focal lengths (a wide field 32 may have as wide a FOV as a 55mm Plossl), and, unfortunately, at higher expense.
f/6.9 is not too hard for eyepieces, so the $60 investment in one of the inexpensive wide angle eyepieces may be a good one. Remember, the shorter the focal length, the more critical (and expensive) eyepiece choice becomes. Ah, for the good old days of my f/15 refractor. It could use anything (Of course, the FOV was also very narrow).
Good Luck.
Don
Good Luck.
Don
#8
Posted 23 June 2004 - 11:26 PM
Thanks for the welcome Lightrap.
To the others, thanks for the info it has all been very helpful and I appreciate all the advice.
brad
brad
