Sorry for the question, I'm just curious why you can't add a filter wheel?
I keep looking at moving to a mono setup and the wheel itself is about the cheapest element considering the price of mono cameras and a good filter set.
Or is it a mechanical / space issue? Are you on a RASA / Hyperstar setup?
There is no good reason for me not to add a filter wheel to the rig. But I'll give you an example. I added an autofocuser to one of my refractors to be more efficient. It worked fine, but it took a long time for the device to find focus each time it made an adjustment. I decided that I knew my temperature changes and my focuser well enough to do it quicker manually. After a while, you get experience and know when to make a focus change as the temperature changes and you know how much to tweak the focus... and it just takes a second. The issue was that I needed a numbers based system to know when I was at focus and I finally got that with the FWHM star averages for each exposure or in Live View in Astrophotography Tools.
To me, the filter wheel is analogous. It is easier for me to pop a filter in the filter drawer than to worry about another software glitch that could occur (although there are manual filter wheels and maybe I should go that route). Ideally some people think you need the filter wheel because they believe it is best to run through the filters for each sub-exposure rather than to do them in batches. Doing them in batches... if clouds come in... you might not get one of your filters into the mix.
I think as you get older (like me) you distrust software and glitches and complexity and try to be as impervious to these potential misfortunes as possible. Not that this is a good approach, but it fits in well with my character and approach to life I won't win any awards, but I won't come in last either...
Rick
