ASIAIR Plus - No dropdown selections for cameras
8 replies to this topic
#1 astrowhat?
astrowhat?
  • Loc: SW Florida
Posted 05 September 2024 - 03:44 PM
I have the newer ASIAIR Plus 256G and wanted to ask a quick question. There are no dropdown options for the primary and guide cameras in the ASIAIR app. I have both a Nikon Z6III and Z8 and was going to see if I could approximate the Z6III with a Z6 or Z6II, Z7, Z7II, etc. but no dropdown selections are available. Am I missing something or is it that the ASIAIR has to recognize the camera from its approved list to  populate those fields?
#2 Infomastr
Infomastr
Posted 05 September 2024 - 09:51 PM
Assuming both are properly connected and powered, the camera has to be in manual mode, bulb exposure, raw format (highest quality), with power saving, noise reduction, automatic ISO, and stabilization disabled.
#3 TomC_RR
TomC_RR
  • Loc: Southern Oregon
Posted 06 September 2024 - 08:57 AM
With my canons i need to push shutter button half way to wake up camera before asi sees it, might have to do the same with your nikon
#4 astrowhat?
astrowhat?
  • Loc: SW Florida
Posted 06 September 2024 - 11:29 AM
Thanks for your reply! That kind of confirms that the ASIAIR Plus needs to recognize the specific camera rather than me picking one from a dropdown menu (like the dropdown menu for the mounts). Unfortunately, both my Nikons are newer and not on the compatible list yet. I’ll have to run the camera separately, if I can. I’m getting the ASI2600MC Pro on Monday, so I can use that while I  wait for the Nikons to be tested.
#5 astrowhat?
astrowhat?
  • Loc: SW Florida
Posted 06 September 2024 - 11:40 AM
It was properly set up, but both my Nikon cameras are not yet tested and not on the approved list. It appears the ASI software only recognizes specific camera models and ignores everything else. I was hoping I could get close in using a similar model, but looks like it’s not set up that way. Example - The Nikon Z6II is on the approved list, but my Z6III  is not. I’ll use a ASI2600MC Pro while  I wait for the newer models to get tested. Thanks for your suggestions.
#6 Infomastr
Infomastr
Posted 06 September 2024 - 04:53 PM
Very unfortunate.  While it makes some sense that the Z6III isn't supported yet, the Z8 isn't particularly new.  You may want to post on the ZWO forums to get developer attention.
  • astrowhat? likes this
#7 astrowhat?
astrowhat?
  • Loc: SW Florida
Posted 09 September 2024 - 12:07 PM
I’m up and running with both the Z8 and the ASI2600MC Pro on the Redcat. The ASIAIR Plus recognizes both and I can use the ASI app. Now I just need a sky with some visible stars in it!! smirk.gif
#8 Klemen1972
Klemen1972
Posted 02 October 2024 - 02:13 PM
hello
so does it work: asiair plus with Z8?
do you have any problems?
k
#9 astrowhat?
astrowhat?
  • Loc: SW Florida
Posted 08 October 2024 - 10:00 AM
hello
k
Here’s what I know. When I connected the camera, the ASIAIR Plus 256GB recognized it as a Nikon Z8 and got the camera to snap images during the focusing routine. Connections were a cable from the DSLR port on the ASIAIR to the 10-pin connector of the Z8 and a USB cable to the ASIAIR from the Z8. How well it works is still unknown until I get a night to test it out in operation, but it appears to function.
