Replacement focuser for a Baby Q
Refractor Accessories
23 replies to this topic
#1 Jeff_Richards
Jeff_Richards
  • Loc: Portsmouth, NH
Posted 05 September 2024 - 06:25 PM
So I've had some time with my Baby Q and have come to the conclusion that I want to replace the focuser. The stock focuser has some very slight variable sag with my imaging setup so I  want something more solid before I move my setup remote. The obvious choices are the Feathertouch and the Nitecrawler. Big advantage for the Nitecrawler is the built in rotator and the near double load capacity. The other one I have considered is the PrimaluceLab Esatto 3 but I haven't seen any reports on the Esatto. The nice thing about the Esatto is the ability to add the Arco rotator at a later date and the load capacity falls between the Nitecrawler and the Feathertouch.
Thoughts? Any first hand knowledge of the Esatto?
Edited by Jeff_Richards, 05 September 2024 - 07:20 PM.
#2 wheels2040
wheels2040
  • Loc: Colorado Springs, CO
Posted 05 September 2024 - 09:10 PM
I can't pass on any first-hand experience, but I was looking at the same options for my FSQ-106 and eventually went with the Nitecrawler. I have one on another scope and it is just rock solid. Not that the Esatto might not be, but the Nitecrawler was a known commodity.
  • Jeff_Richards likes this
#3 Jeff_Richards
Jeff_Richards
Posted 05 September 2024 - 09:27 PM
The Nitecrawler does have a substantial advantage in load capacity and it's made in the USA. I do like the ability to take steps with the Esatto/Arco. I can save money now and just get the Esatto and add the Arco later if I think I want it (likely).
#4 Mbenj2405
Mbenj2405
  • Loc: head Chezzetcook Nova Scotia Canada
Posted 06 September 2024 - 08:18 AM
The Nightcrawler has an abundance of adapters available which is very nice.
#5 Rasfahan
Rasfahan
  • Loc: Hessen, Germany
Posted 06 September 2024 - 06:43 PM
The Esatto is nicely machined, lightweight, very accurate and has been reliable for me.
#6 Jeff_Richards
Jeff_Richards
Posted 06 September 2024 - 08:03 PM
I think I'm going to go with the Esatto and will add the Arco later.
#7 lumos
lumos
Posted 08 September 2024 - 06:38 AM
I really like my Esatto 3" on the FSQ85. To get you going try a step size of 5000. I use mine with the new Q 0.7 reducer and needed the extension to reach focus.
#8 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 07:10 AM
Thanks for the tip Lumos! I will also be using the new .73x reducer and I ordered the 25mm extension based on my current focus position. I will eventually add the Arco but just wanted the Esatto for now to make sure I'm happy with it before dropping the much higher price for the rotator.
#9 wheels2040
wheels2040
Posted 08 September 2024 - 12:38 PM
If you haven't seen it yet, PrimaLuceLab posted a YouTube video on outfitting the BabyQ with all of their components
https://www.youtube....AQ4xn4ljP8&t=2s
  • Jeff_Richards, leviathan and lumos like this
#10 lumos
lumos
Posted 08 September 2024 - 01:35 PM
Sadly I do not have the back focus for the Arco as I use an OAG and a filter wheel. At 330mm focal length I do not really need an off axis guider.  Before I put this wide field scope together I assumed that I would not need a rotator as the whole universe would fit in the field of view. How wrong I was.
#11 lumos
lumos
Posted 08 September 2024 - 01:53 PM
Just a note of caution, when I first ordered all the parts I ordered the PL3600272 Adapter from M81 to M72 with stop ring for ESATTO 3" and ARCO 3". This would not work (I assume you will need this when you get the ARCO) and what I needed was the different gender from the PrimeLuce PL3600272 (M81 female to M72 female). I seem to have the same part numbers for both, perhaps that I why I ended up with the wrong part. This is a €90 adapter so it is certainly lower cost to go straight for the ARCO.
The other parts are
PLLEST3-B ESATTO 3" robotic focuser
PL3600271 Adapter ESATTO 3" for Takahashi FSQ85
Please excuse my outrageous cabling in the picture.
  • Jeff_Richards and leviathan like this
#12 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 02:14 PM
No reason why this shouldn't work. I'm running my Baby Q at 330mm with a camera, filter wheel and OAG. The camera set up puts me at approx 55mm which is correct for the Sky 90 adapter for the .73x reducer. My stock focuser is at approx 135mm (obviously with room either way for focusing) where the reducer screws in and that is about where the Esatto will sit if it is about half way out with the 25mm extension tube. The Arco is just about the same 25mm as the extension tube so I would just pull the tube and replace it with the Arco and connector ring.
#13 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 02:19 PM
Yeah, I saw that and it is what pushed me over the edge. I already have the PrimaluceLab rings and Losmandy dovetail plate so the Esatto (and eventually Arco) should look good. Plan on adding the Giotto/Alto as well.
#14 lumos
lumos
Posted 08 September 2024 - 02:25 PM
That is really interesting if it adds up. My calculation was
Mechanical back focus from QB 0.73 is 72.2mm plus .67mm of ray Antlia filters so 72.87. Sky 90 is 16mm, M54M to M48M 2mm, M54 sensor tilt adapter 5mm, OAG-L 17.5mm, EFW 20mm ASI2600MM 12.5mm. That leaves me with with 73mm out of 72.87mmmm and I need 20mm for the ARCO. Of course I could get a custom part to replace the SKY90 that takes me from M56F to M54F.
I would be delighted to be proved wrong.
Edited by lumos, 08 September 2024 - 02:28 PM.
#15 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 02:31 PM
Mechanical back focus from QB 0.73 is 72.2mm plus .67mm of ray Antlia filters so 72.87. Sky 90 is 16mm, M54M to M48M 2mm, M54 sensor tilt adapter 5mm, OAG-L 17.5mm, EFW 20mm ASI2600MM 12.5mm. That leaves me with 15.87mm and I need 20mm for the ARCO. Of course I could get a custom part to replace the SKY90 that takes me from M56F to M54F.
Well a "standard" camera/fw/oag should be close to 55mm (I use QHY components) which is what the Sky90 adapter is looking for. I don't have a tilt adapter in my set up and if I so I don't have that 5mm in the train.
#16 lumos
lumos
Posted 08 September 2024 - 02:35 PM
Sorry for being dense, mine is 55mm as I removed the 5mm tilt adapter to allow the 5mm tilt adapter that bolts on to the ZWO filter wheel. How can you get the additional 20mm for the ARCO?
#17 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 02:39 PM
The Arco is just about 25mm thick with the Esatto adapter ring...you take out the 25mm extension tube and connect the Arco directly to the Esatto (how the video shows).
#18 lumos
lumos
Posted 08 September 2024 - 02:42 PM
Please excuse my muppetry. Of course, the ARCO goes before the QB .73 so does not come out of the back focus.
#19 Jeff_Richards
Jeff_Richards
Posted 08 September 2024 - 02:48 PM
And it looks like you want the 40mm front extension if you want to use the 1.01x corrector for native 450mm fl.
  • lumos likes this
#20 lumos
lumos
Posted 09 September 2024 - 01:42 AM
Thank you so much for your help. Also the video was useful. I need another adapter, the PL3600458 to connect to the ARCO and as you say I will remove the 25mm spacer.
#21 Jeff_Richards
Jeff_Richards
Posted 10 September 2024 - 10:26 AM
My Esatto arrives tomorrow. I'll probably look at adding the Arco by the end of the year to get everything tested out before moving my system remote.
#22 Jeff_Richards
Jeff_Richards
Posted 15 September 2024 - 08:44 PM
Thanks lumos for the 5000 step size for NINA autofocus, it worked well! I can also safely say that the you don't need to add the 40mm PrimaluceLab extension before the Esatto if using the 1.01x flattener, just use the supplied 50mm extension tube supplied with the FSQ as shown on the chart. So if you have an ARCO (or the 25mm M81 extension tube), the Esatto will work with the 1.01x flattener or the 0.73x reducer with supplied material with the Baby Q. Very happy with the install and the quality of the Esatto. Can't wait to add the ARCO.
#23 Dunk
Dunk
Posted 17 October 2024 - 02:31 AM
I'm struggling to see how I can add an Arco to my existing setup.
Right now I'm at:
Esatto + PreciseParts adapter (12mm)  + TKA23250 (52mm) + 1.01x + <regular 55mm/56.2mm everything else>
Looking at adding the Arco (based on the video above) I get:
Esatto + PL3600317(40mm) + PL3600458(1.5mm) + Arco(23mm) + PL3600458 (5mm) + 1.01x + <regular 55mm/56.2mm everything else>
The Arco setup is 69.5mm vs 64mm.
The video above is a little vague in exact adapters. Does anyone have a working Esatto + Arco + Flattener setup?
Edited by Dunk, 17 October 2024 - 02:32 AM.
#24 Jeff_Richards
Jeff_Richards
Posted 17 October 2024 - 03:50 AM
Works fine with the flattener or reducer. Use the PLL Tak adapter after the ARCO and then all the normal Tak stuff for the flattener. I just added the ARCO but used to have the 25mm M81 spacer so the ARCO just replaced that.
Also tagged with one or more of these keywords: Refractor, Accessories
