M103 with a Takahashi FC-100DZ and ZWO ASI678MC
Astrophotography CMOS DSO Imaging Refractor
1 reply to this topic
#1 james7ca
james7ca
  • Loc: San Diego, CA
Posted 07 September 2024 - 08:46 AM
The open star cluster M103 as taken Friday morning under Bortle 7 skies. I lost about 25% of my subs to intermittent high clouds and I ended up with about 36 minutes of total integration time. The faintest recorded stars seem to be just short of magnitude 19 but it's hard to know exactly since this image goes deeper than my common references (ASTAP catalog or WikiSky.org). WikiSky shows fainter stars in their DSS2 All Sky Survey but they don't label/identify many stars once you reach mid-18 magnitude.
Image capture was with N.I.N.A with processing in PixInsight and Photoshop 2024. Click on the preview to see at full size (1600 x 938 pixels) and to read all of the capture details that are in the captions. North is oriented up and the reproduced image scale is approximately 1.3 arc seconds per pixel (the original capture scale was 0.52 arc seconds per pixel).
[UPDATE]
I did a dump of PixInsight's Gaia data base down to magnitude 20 and compared that to a few coordinates for the faintest stars in my image and I found a very faint hint of a few stars that were at magnitude 19, but the stars that are clearly recorded seem to be a few tenths under 18.5. I also used ASTAP to measure the limiting magnitude and it returned a magnitude of 19 using all of its defaults. So my estimate remains somewhere between 18.5 and 19.
[/UPDATE]
Edited by james7ca, 07 September 2024 - 11:26 AM.
  • EricCCD, Mark Strollo, Joe F Gafford and 8 others like this
#2 james7ca
james7ca
Posted 08 September 2024 - 12:19 AM
Thanks to everyone for the likes.
I feel that it is actually possible to get too many stars or too much exposure on some open clusters and so here is a version of M103 where I've reduced the number of small stars and then added flare and diffraction spikes to the brighter stars using the Photoshop plug-in Star Spikes Pro. You might call this the "artistic" or maybe even classic version of M103.
Framing and image scale also matter and I think the FC-100DZ and the ASI678MC actually work pretty well on many of the smaller star clusters.
Edited by james7ca, 08 September 2024 - 12:31 AM.
Also tagged with one or more of these keywords: Astrophotography, CMOS, DSO, Imaging, Refractor
