I had the scope out last night to view Jupiter, on the manual Super Polaris mount. As I said elsewhere, that scope is too much for a super Polaris. Since Jupiter was near the zenith, I had a tough time aligning on it. The finder is straight through, and I find myself unable to contort enough to look through the eyepiece, so I did the thing where I view the scope and Jupiter from the side, and move the axis I'm closest to until the OTA points in the direction of jupiter, then view along the other axis and repeat. That usually got me close enough to get jupiter in or very near a wide field view in the 'afractor. I quickly noticed a problem with focusing. Jupiter seemed to slowly drift out of focus a couple times. I had to tighten the tension knob to keep it from doing that. Next thing I noticed was a slight flaring of the planet just outside focus, that didn't quite go away at focus. By moving the focus knob back and forth, I was able to see that because the focuser drawtube is too loose in the focuser body, it's going off axis slightly when racking it in and out. This actually took a while to confirm, as the scope shook for a good 5 seconds after each tough of the knob.
I need to replace that focuser, or fix it somehow so it stays concentric. Considering I paid $300 for the scope and mount, I expect a focuser will more than double my investment. Hopefully, it'll be worth it. I'm also likely to invest in or make a Dovetail plate for the scope rings from the LXD600 before I fix the drive on the LXD600.
Considering I was "retired" from JPL during the November layoffs, one might think I'd have time to do all this stuff I've been wanting to do with the hobby for the past 5 decades. But my favorite saying has become "the trouble with retirement is you don't get a day off."
-Tim.
