Hi.
My ZWO EFW has developed a problem, which may or may not be new.
I have LRGBSHO filters loaded, in that order. I have unidirectional setting turned ON in the ASCOM properties. I know this setting works because I can see that it takes a short amount of time to go one filter down the list, but a much longer time to go one filter up the list.
Here's the problem. I have a sequence where I take a bunch of G subs, then a bunch of R subs. The beginning of R subs all have misaligned dust motes, until an autofocus kicks in which is set to work with L filter and filter offsets. After the autofocus is completed, all of the dust motes become aligned.
It seems to me that there's a difference in position when switching from G->R and L->R, even though G->R does go through L position.
Questions:
1) Have you seen anything like this before?
2) What is the fix?
3) If I run Recalibrate option from ASCOM properties, will I have to take new flats?
Thanks.
