ASIAIR mini dualband filter issues
Astrophotography Equipment
2 replies to this topic
#1 Rpadgett
Rpadgett
Posted 12 September 2024 - 04:49 PM
Using asiair mini with recat ii on AM3 mount with Pixinsight software
Trying to process rgb with dual narrowband HaO3 subs
Read Pixinsight allows auto integration withusing weighted batch preprocessing
How to set up narrowband subs to have metadata different than rgb?
My Seestar 50 codes filtered and nonfiltered files as LP and IRCUT
Cannot find a way to set up narrowband without using a filter wheel
Also in autorun; bins 1 thru 4  - can they be used to separate lights as rgb and narrowband?
Confused
#2 nwcs
nwcs
  • Loc: Tennessee
Posted 12 September 2024 - 05:01 PM
Short answer is you can’t. When I use dual band and rgb on the same target I set up the exposure tolerance in WBPP to keep the files separated. I also use the keyword ability in folder names to help. So I might have a folder named Filter_RGB_Group_Set1 and Filter_DB_Group_Set1 and set Filter and Group as keywords in WBPP.
  • Rpadgett likes this
#3 Rpadgett
Rpadgett
Posted 12 September 2024 - 05:25 PM
Original Post adding  533MC Pro as Camera used
Also tagged with one or more of these keywords: Astrophotography, Equipment
