Here is a Q&D method which will get you very close.No credit to me, I copied from someone here on CN a while back, may have been Vic !
Q&D Collimation !
1. Mask over the secondary mirror with a piece of white paper that just fits over the reflective part. (Laid flat, the paper will be an ellipse- i like to mark the center of it by folding it along the hor & vert axis and marking cross-point with a dot.)
2. Looking through the focuser fully extended, adjust the spider mounting and the secondary rotation so the white area is exactly centered in the focuser view and appears round.
3. Remove the paper mask and insert a "Cheshire" type eyepiece (or a plug that fits into the focuser with a .5 to .8mm hole in the exact center. An old 35mm film can works perfect for this)).
4. Adjust the secondary mirror alignment screws so that the main mirror appears centered in the view seen through the Cheshire eyepiece. Ignore the reflection of the secondary in it.
5. Now adjust the main mirror (while looking thru the Cheshire eyepiece) until the reflection of the Cheshire eyepiece hole appears centered exactly in the main mirror. If the main mirror has a dot in the center, that will help. This should get you in pretty good shape.
Sorry, that's not my method!
1.) First--I don't recommend masking the secondary mirror. If the OP wants to minimize reflections, he could mask the primary mirror with a 13.1-inch circle (with a visible center marker). This minimizes the secondary mirror placement correction to three circles--the bottom edge of the focuser, the actual edge of the secondary mirror, and the reflection of the masked primary mirror. The additional center marker on the primary mirror mask is also useful as a centering reference for the focuser axis (when using a cross hair (sight tube) collimator or a simple thin beam laser).
2.) By "adjust the spider mounting..." I assume you mean, ...adjust the secondary mirror tilt and rotation (and the secondary mirror tilt and offset). These adjustments will ultimately make all three circles concentric and, more critical than perfect concentricity, the primary mirror center marker will be centered relative to the bottom edge of the focuser. Note that this means the actual edge of the secondary mirror may mot be perfectly concentric to the other two circles, which is OK since a small secondary mirror centering error will have a minimal, visually undetectable, impact on field illumination. It's more critical that the reflection of the primary mirror is centered relative to the bottom edge of the focuser, which ensures optimal focus across the eyepiece field of view.
4.) When adjusting the secondary mirror tilt, the "quick and dirty" adjustment is referenced to the primary mirror center marker OR the bottom edge of the focuser. The actual edge of the secondary mirror is NOT a good reference for this adjustment, and more often than not, when used as the reference for secondary mirror tilt, will actually misalign the focuser axis.
5.) Adjusting the primary mirror tilt is always the final step of "quick and dirty" tool alignment. This adjustment centers the coma "free" field diameter (aka, the sweet spot) in the center of the eyepiece field of view.
If the secondary mirror placement is more or-less correct (the three circles are more-or-less concentric), steps 4 and 5 are the typical "Q&D" collimation.
Assessing, and correcting, the secondary mirror placement (usually rotation and/or offset assuming the other mechanicals ("squared" focuser and spider, "centered" spider, primary and secondary, etc.) are more-or-less correct) is not Q&D--even when you have the right tools.
The collimation order is always:
1.) Assess and correct the secondary mirror placement (three circles).
2.) Assess and correct the secondary mirror tilt (the primary mirror center marker is centered relative to the bottom edge of the focuser)
3.) Assess and correct the primary mirror tilt (the reflection of the underside of the focuser (inside the reflection of the secondary mirror) is centered relative to the primary mirror center marker).
If you change the secondary mirror placement (step 1), you must repeat steps 2 and 3.
If you change the secondary mirror tilt (step 2), you must repeat step 3.
Last but note least, there is a 4th step--verify the primary mirror tilt tool alignment using a star alignment. I like Mike Lockwood's method; http://www.loptics.c.../starshape.html
(Note that this only verifies the primary mirror tilt adjustment! Once verified, you can trust your tool alignment to deliver the correction necessary for optimal performance.)
Edited by Vic Menard, 15 September 2024 - 12:24 PM.
