Got an old refractor you want to improve?
17 replies to this topic
#1 RichA
RichA
  • Loc: Toronto, Canada
Posted 14 September 2024 - 09:20 PM
This is anti-reflection coating in a bottle. It actually drops the reflectance of uncoated glass surfaces from 4% to about 0.6%.  Apparently, the National Ignition Facility uses some thing like it because it can be stripped off with drain cleaner and re-applied, no vacuum chamber needed.  They do it because the lasers they have damage the coatings and they have to be renewed because the glass plates to too expensive to just throw out.
https://www.alibaba....0335087347.html
  • davidc135 likes this
#2 Scott in NC
Scott in NC
    Refractor Aficionado
  • Loc: NC
Posted 14 September 2024 - 09:24 PM
Interesting, but I have doubts that it can be applied smoothly enough to not alter the wavefront of the optics that you’re applying it to.
  • tony_spina, Jon Isaacs, alnitak22 and 4 others like this
#3 RichA
RichA
Posted 14 September 2024 - 09:31 PM
Well, you can dip it, spin coat it.  Spin coating is how they apply it to the lens plates at the NIF.  I don't think it matters because the coating ends up very thin, just like a regular 1/4 wave anti-reflection coating.  It's not like some glue or something.  They give a shot of it in this video.
https://www.imdb.com...ref_=fn_al_tt_1
https://coatings.ucolick.org/ar.html
Interesting side note;  the Keck telescope uses a giant version of an ADC!
Edited by RichA, 14 September 2024 - 09:36 PM.
#4 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 14 September 2024 - 09:56 PM
For a windshield or eye glasses... why not try it on something else first. I find it hard to believe that the layer will be uniform or bring the reflectivity at that surface to 0.6%. No harm in trying on specimens. The transmitted wavefront will pick up the NΔT distribution over the surface; in reflection, double that. I was a vacuum coating operator/tech/engineer/scientist for 12 years. Never worked the chemical deposition stuff though. My boss, who was a chemist, dabbled in those things... but to no avail.
OH! You would have to be able to strip off the old coating, if present. Otherwise, the liquid stuff will increase the reflectivity by ~frustrating~ the existing coating. I once made that mistake... with nearly disastrous results, before figuring out what was going on. I'm guessing if not applied properly --- might wind up looking like a soap bubble or oil slick. I actually researched this phenomenon to determine/measure non-contact the thickness of the tear layer on the human eye cornea. The context was Bausch & Lomb Eye Drops and contact lenses development. Pleases me that to this day, one of B&L's most profitable products is --- OTC and Prescription Eye Drops!   Tom
  • Jon Isaacs, Scott in NC, Skywatchr and 9 others like this
#5 Jon Isaacs
Posted 15 September 2024 - 03:28 AM
Drain cleaner is sodium hydroxide.  Sodium hydroxide etches glass.
I am also skeptical about this providing a uniform layer. This is meant for your windshield.  A windshield is not an optical grade surface.
  • Scott in NC, doctordub, TOMDEY and 2 others like this
#6 TOMDEY
TOMDEY
Posted 15 September 2024 - 10:52 AM
And this reality regarding uniformity >>>    Tom
  • peleuba, Skywatchr, davidc135 and 1 other like this
#7 Jon Isaacs
Posted 15 September 2024 - 10:58 AM
"How to turn your favorite refractor into a Kaleidoscope."
  • Skywatchr, ken30809, TOMDEY and 4 others like this
#8 jimeh
jimeh
Posted 15 September 2024 - 11:06 AM
This is just Rain-X. Don't put it on a telescope
  • TOMDEY and Steve Cox like this
#9 Dave Novoselsky
Dave Novoselsky
  • Loc: SE Wisconsin/Chicago
Posted 15 September 2024 - 12:38 PM
Try liquid unobtainium, works like a charm
  • Skywatchr and Steve Cox like this
#10 RichA
RichA
Posted 15 September 2024 - 08:01 PM
The windshield material is just one example of the stuff.  There is likely a professional optical product i've yet to locate.  I highly doubt the people working with laser optics, which are often some of the most accurate optics made, would use something detrimental to them.  In the video below, they explain it to a degree and show how the material is applied.
https://www.youtube....h?v=0qT48BVsI84
Edited by RichA, 15 September 2024 - 08:09 PM.
  • TOMDEY likes this
#11 topomountain
topomountain
  • Loc: nc mountains
Posted 15 September 2024 - 10:15 PM
hey guys and gals
anything they sell on alibaba is lab tested and guaranteed to work miracles on your lenses
and for that matter, someone let me know how it does on your windshield!
  • Jon Isaacs and Steve Cox like this
#12 Jon Isaacs
Posted 16 September 2024 - 04:00 AM
I worked with Laser optics.  Some of it quite precise.  Some is not very precise.  That lambda/400 etalon was quite precise.. The optical windows in our ruby lasers, not so much.
  • TOMDEY likes this
#13 deSitter
deSitter
    Still in Old School
Posted 17 September 2024 - 11:45 AM
hey guys and gals
Rich is a pretty smart guy, snarking him is low-brow. This might be a great way to save an eyepiece with a failing coating. I would like to hear more., It is certainly possible a layer down to 1/10th wave might be deposited. Something with extremely low surface tension that will be drawn uniformly into an even layer by molecular forces. Rich is right, those laser optics people have huge budgets and don't suffer magic.
-drl
Edited by deSitter, 17 September 2024 - 11:45 AM.
#14 RichA
RichA
Posted 17 September 2024 - 01:38 PM
-drl
It's only fair AR coatings can be applied this way, since you can also silver a mirror relatively easily with methods available.
I've got a 1930's 70mm apo lens, 3 elements, none are coating.  This could be a benefit for it.  I've also got a 4 inch Japanese achromat with deteriorating coatings that might need it.  Lastly, old C8's purchased without Special Coatings could be improved.
#15 RichA
RichA
Posted 17 September 2024 - 01:39 PM
These optics are exposed to 500 trillion watts of laser power.  Because of that, the optics must be precise and dust free.
  • deSitter likes this
#16 Wildetelescope
Wildetelescope
  • Loc: Maryland
Posted 17 September 2024 - 02:54 PM
So that video illustrates why one should not try this at home, even if you had a "professional grade" coating in a bottle, even if you have a spin coater in the garage.    Look at all the precautions taken to eliminate dust contamination, lol.    Serious question.  Out of curiosity, ARE the coatings applied to refractor optics applied via spin coating?   For some reason I have been under the impression that Vapor deposition is what was typically used.    Genuinely curious.
Cheers!
JMD
#17 deSitter
deSitter
    Still in Old School
Posted 17 September 2024 - 08:49 PM
Dang that is many watts :)
500 trillion watts = a string of Christmas bulbs 10 billion miles long :) More than 2x distance to Pluto :)
-drl
#18 topomountain
topomountain
  • Loc: nc mountains
Posted 18 September 2024 - 09:52 AM
-drl
this was not a dig at richa, i have read many of his posts and look forward to his tests of this process should he try it....
im all for mc gyver scope mods.... im all for alibaba etc, its just also a risky thing to believe ANY hype or promises from any Chinese vendors... ive got some nice Chinese scopes, but hey the internet at large is full of hot air, and alibaba even more so, just a little harmless fun,
all due respect to richa and other folks pushing the envelope
