Hi all.
I'm getting my 10" Dob in about 2-3 weeks, and it's a GS brand, comes with a 2" focusser with a 1.25" adapter, so I can use both size EP's.
What's the difference between 2" and 1.25" eyepieces?
I've heard from knowledgeable sources that there's generally no difference, and that the quality of the 1.25" EP's are actually better than the 2"s.
He said the only real benefit of the 2" EP's are the comfort of viewing, as you don't need your eye directly over the eyepiece as you do with a 1.25".
The conondrum i've got, is whether to buy the accessories in 2" or 1.25" sizes.. Eg: barlow lens, moon filter, OIII filter etc.. They're much more readily available in the 1.25" size, plus they're cheaper than in the 2" size.
Your thoughts and suggestions are most appreciated
Well, to disagree with some who have posted, a 2 inch eyepiece is *not* necessarily of "lower quality" than a 1.25 inch barrel eyepiece. Its the execution of the design which counts, and for 2 inch eyepieces, this means a *lot* of money if you want halfway decent performance. 2 inch eyepieces are generally used when larger fields of view are needed and can't be supplied by 1.25 inch barrel eyepieces. The limit to field of view is the eyepiece field stop, which is often the opening at the front of the eye lens (not always at that location in some wider-field designs). As such, it is the "bottleneck" which can cut off the light coming from wider angles. The true field of view in a telescope is: TFOV = 57.296*efsd/Fl, where "efsd" is the eyepiece field stop diameter and "Fl" is the focal length of the telescope. With 1.25 inch eyepieces, the maximum field stop diameter is about 27mm, so you can see what your maximum field would be here. With 2 inch eyepieces, the field stop can get as large as 44mm, so you could get quite a bit more field of view if you wanted to. The use of 2 inch eyepieces is especially common with the larger Newtonians, as they almost have to have at least a few 2 inch barrel eyepieces to just get a low enough power and a wide enough field to see a some the larger objects in their entirety (which a smaller telescope might easily fit in its lower power field with an 1.25 inch barrel). With a 10 inch, you are kind of on the dividing line between needing a 2 inch and not needing one, so you can probably get away with not having one right now. For the maximum field of view, you might benefit from a larger 2 inch eyepiece, but many of the less expensive ones (under $250) do not perform well at shorter f/ratios. If you really want good performance in a 2 inch eyepiece, I would recommend that you save your money for a while and then buy a TeleVue Nagler or Panoptic. Clear skies to you.
