Can you load them all into an image container, perform a dynamic crop to get them all to the same dimension, then run them through the integration steps?.
Alternatively, manually performing the registration step first should bring them all to the same size/resolution.
That would be another option I expect. I may give that a spin.
OK, so this begs the question... Why would you have that many substacks? I can see three or four if you were imaging with multiple telescopes/cameras across multiple years, but twenty to 100? All OSC? How does that happen? Are you trying to integrate the work of a bunch of different imagers?
In any event, you are correct that WBPP will want all files to have the same dimensions, so you're going to have to perform a star alignment before you run them through WBPP for the integration. Then you can load the files as outlined by idclimber, and just turn off registration as a step.
Seriously, though, how did you wind up with 20 to 100 substacks of OSC data?
I regularly capture thousands of short exposures due to leveraging my Alt/Az Goto Observational Dob for Deep sky and stacking in chunks makes the whole process fairly easy as I have it pretty automated with a SIRIL script.
So I stack in ~10 minute substacks and I describe it a bit here:
https://www.cloudyni...s#entry13656982
and I share a bit of my SIRIL script that does it here:
https://www.cloudyni...s#entry13344157
and I talk about the impact on image quality here:
https://www.cloudyni...s#entry13408317
Edited by smiller, 17 September 2024 - 09:23 AM.
