Well, not sure whether I should post this here, as I KNOW there will be a LOT of variable achromat vs APO comments, and some disparaging ones re: using achromats for solar under continuum "white-light" full/reduced spectrum observing. Oh well... here we go!
I post this mainly as encouragement for those with these or similar scopes who may wish to do solar observing and kick it up a notch or two from maybe what they are currently doing now. These are my "quick set-up, solar scopes"; I have several APOs also, but these are currently the two largest refractors I have (not counting my APM 120-45SDs, which are just nuts on Sol...). Both are employed with the following filters:
- Lacerta Lac-2s 2" Brewster angle Herschel Wedge (used/shown in pics below), <OR> APM 2" Herschel, <OR> Baader Mk1 2" Herschel wedges. Current favorite is Lac-2s...
- Baader ND3.0 on wedges, exc. APM which has its own integrated filters.
- Hoya 2" polarizer, plus Baader SA filter. (120mm scope - ST120)
- In lieu of (#3), with 152mm RFT scope, use a Player One UV/IR cut (OD4.0 outside vis range) filter, THEN Baader SA (semi-Apo), then polarizer (linear Hoya, B+W, or Baader, usually latter)
My Skywatcher ST120: on Oberwerk TR3 Maple Tripod, using Skywatcher AZ5 head...
My TS Optics 152 f/5.9RFT on Stellarvue M2C (alt-az) mount, on Oberwerk TR3 Walnut tripod:
So... how DO THEY do?
Well, pretty amazing, actually! The ST120 has been up to 86X in excellent seeing, but usually to 60-71X, depending upon conditions. The 152 has yet to go over 80x (only seeing limited as of late, had to repair the tripod before using this week with my newer Lac-2s Wedge), but handled 69x in very good seeing so far... No issue going higher on either, just seeing limited so far.
In the ST120, the tint of the sun is a pale straw yellow color, or deep cream. (due to the SA filter blue reduction); in the TS152RFT, the sun is a pale cream-white - very close to but NOT quite pure white.
Using the wedges, esp, the Lac-2s and Baader Mk1, I do see a very small amount of CA residual on the limb. very thin pale blue on the ST120, with a VERY thin pale yellow. Same on the RFT, though the outside fringe is more of a pale mauve-deep blue. Estimated to be approx 1% or less of the disk. Very low. On axis, the fringe disappears - so this is more of a field curvature-related OOF color fringe. It can be nulled by either positioning the limb more mid-field, or by eye placement within the field when observing that region.
However, during viewing of disk detail, spot groups, plage, pores, spot penumbrae, etc. The views are sharp and not at all plagued by color fringing. During arcsecond to sub-arcsecond seeing, level of granular details are very close to my APM 120-45SDs, which ARE APO binoculars. I'd say the 152RFT beats out the ST120 by a bit, which is expected since it is a larger scope, with a longer f-ratio.
When NOT using the wedges, I use in the ST120 an APM 2" BK7 prism, with a custom CA-reducing filter stack (SV MV2+Astronomik L-3) on the diagonal, and full aperture Kendrick 120mm filter. (AS Film). On the RFT, I use a Euro-EMC 144mm aperture filter w/APM "blue" mirror diagonal (has additional violet/blue partial cut for SCT/Achromats) and the same filter stack. I can also use just a SA semi-apo, or a Hoya L44/Baader UVIR cut filter in lieu, which also does well, though the tint is admittedly a pale straw in that last stack - the SV/L3 combination is very close to pure white, and only maybe 1/3 (if) of the residual fringing seen in the wedges as described above.
Nonetheless, these scopes deliver serious solar views, and work very well. The A-A mounting allows some nice "scans" over the sun during nominal field drift as these are manual, unpowered/non-motored mounts.
AR 3828, the newest active region's spot could be seen at 23:25UT (Sept16/24) showing easily its "notch" in the umbra plus a forming plage or light bridge - pretty shallow angle, with limb CA nulled, and was very fringe-free/CLEAN and visible during arcsecond- level seeing. Several small pores in the mid disk were easily seen also, and AR 3825 had amazingly well-shown plage and granular deep structure during this time. Also, the small group above AR3824 nearer mid disk, but to the west wide, had two bright hot spots, one next to a small spot/pore. Was very obvious during examination of that region at 69X in the 152RFT.
Solar altitude was about 20 degrees altitude here in Edmonton Alberta at that time. So even below 25 degrees, with seeing this wedge system and the 152 did a superb job! There was lots more visible, but I think the point was made here...
So, yes, not an APO... got it... but worthy of exceptional solar details? Absolutely, with proper execution and use. EPs generally used are APM UFF 15/18mm or TS UWAN 7/10/13/16mm (really like them!) or TV Nagler Type 6 in similar f.l.: 9/11/13mm usually.
Today and over the weekend, the UFF 15mm (60X) or UWAN 13mm (69X) were used in the RFT, with the Lac-2s Wedge. The biggest surprise to me is the level of detail despite having FOUR filters in the chain. That was a lot!
I used my 152 on the April eclipse from Edmonton with my Baader wedge and it did a dandy job as well. What I like about the Lacerta *Lac-2s is both its wider brightness range, and the more complete polarization of the light, which, when paired with a good linear polarizer, REALLY makes the plage and granular structures very deep - even mid disk, when present. Also Penumbral filamentary details really pop as well during excellent seeing (in all refractors - incl. my SV/TMB105 and SV90T Apos).
*the Lacerta has been modified/augmented: I replaced the stock 2" eyepiece system with a TS 15mm adapter ring, and ZWO 4mm m54-f48 insert ring (to place a 48mm ND3.0 filter into the body, similar to a Baader wedge. This way I get deeper room for various stacked filters and eyepiece barrels. Works very well, and IMO better for general visual use. I can always revert to stock if I wish to, but why?!
If anyone has questions, or comments they are welcomed. I would prefer not to have any disparaging arguments here. The reason for the post is information gathering, and to use an Achromat when it is required or perhaps the only scope one has. Not in my case, but this testing has yielded very superb results - in both scopes, which also do superbly on planetary and lunar with the mods mentioned above. Again, no not an APO, but they do VERY well regardless. 152RFT has been well over 200X on planets and ST120 from 150X to 200X when seeing permits with v.good to even dare I say, excellent, results.
Clear skies and wishing you lots of good detail!
Darren
Edited by Spectrum222, 17 September 2024 - 01:29 AM.
