Forgetting the issue of one size fits all (it really doesn't exist), there are a few basic things needed to get started.
Telescope
Mount to hold it
Camera to take pictures
Computer to control and/or process images.
Shorter focal length refractor telescopes are the easiest to begin with. They tend to have a wider field of view and can produce quite good results.
The Earth rotates, so a mount needs to compensate for that. The best are equatorial and the lower cost option a rotator mount.
The two camera area options are basic DSLR cameras and dedicated astro cameras.
A computer is usually used to control the telescope during astrophotography sessions. Some models of DSLR cameras have built in processing for this, but astro cameras do not. The most common units here are laptops and miniPC computers.
Cost is an open ended area. Scopes range from a few hundred to tens of thousands. Mounts, cameras, and computers are in a similar range.
The lowest cost route to get started might involve a basic DSLR camera and a rotator mount. Rotator mounts start at about $500 and good used Nikon models are a few hundred. You can get fairly decent results with kit lens that comes with the camera.
Moving into the equatorial mount category gets more costly fairly quickly. Lower cost EQ mounts start at about $1000. However the common view of most in the AP area is that the three most important things are: mount, mount, mount. Expect a range starting at 2K for a good EQ mount.
A reasonable cost 70-80mm refractor telescope is a good place to start. These start about $500-$800.
One can use a DSLR with a scope/mount combo, but most prefer the dedicated approach. ZWO has astro cameras from about $300 up. Their newer ASI585MC Pro is a good camera that is also cooled.
The easiest computer approach is a Windows based laptop. I started with this but today I use miniPCs instead. After I set things up and align, I move inside (home or car) and control all from there. Doing this does involve more gear to do WiFI things.
AP is a very rewarding hobby, but tends to be a never ending one for many. For most, starting simple and working out from there is the best approach.
