Tasco CL find
18 replies to this topic
#1 Mcloud
Mcloud
  • Loc: Pittsburgh aka Gotham Cloud City
Posted 23 September 2024 - 05:19 PM
What should I ask ty guys
https://erie.craigsl...7779652555.html
#2 apfever
apfever
Posted 23 September 2024 - 05:40 PM
What should you ask, or what should you offer?
I think most would baulk at $600 for what is shown in the ad.
#3 jragsdale
jragsdale
  • Loc: Idaho
Posted 23 September 2024 - 05:50 PM
$200 max. Maybe $300 if lens is flawless, you really want one and don't have to drive far. Buying it sight unseen; $100. No lens pics is always disappointing.
  • ericb760, Bomber Bob and Garyth64 like this
#4 Bungee
Bungee
  • Loc: South Central Missouri
Posted 23 September 2024 - 08:33 PM
In my market I've passed on a couple at $150. Bottom line is how bad you want it.
#5 Cavs56
Cavs56
Posted 24 September 2024 - 04:49 AM
I don’t understand why the 10-TE is usually priced much higher than the Sears 6344. One is RAO the other is SYW. The mounts are almost identical. Performance is similar. Both 80mm x 1200mm. There’s a 6344 on Facebook marketplace in Illinois I believe for $225 looks perfect in box complete. I would rather have that one. It also takes the Vixen 1.25 adapter.
  • Bomber Bob likes this
#6 deSitter
deSitter
    Still in Old School
Posted 24 September 2024 - 11:40 AM
Seems to be complete and in good shape. If glass is good and trash can lid is over it, $250.
-drl
#7 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 25 September 2024 - 10:39 AM
The answer may be just what you stated, "one is RAO the other is SYW".  But the 6344 has a 76mm x 1200 lens like the Tasco (76.2mm), and 6339a
My 1254 ATCO 80mm x 1200mm is made by APL.  It doesn't have the RAO stamp either.  But it has a very good lens.
One thing that I like very much about the 1254, and the 6344, is that their tubes are longer than the 10TE's and 6339a's.  I have had a few of those scopes and I didn't like the long skinny drawtubes.  Now I use the 1254 for outreach events.  I have a 10TE-5, that is in excellent shape, I would let it go for 275.
Edited by Garyth64, 25 September 2024 - 10:43 AM.
#8 Cavs56
Cavs56
Posted 25 September 2024 - 11:44 AM
One thing I actually do like about the Sears 4540 is the long skinny draw tube. Focus is so fine. I also like the mount a little better than the 6344. I can move the object in field of view while observing without vibration. The 6344 was very sensitive. I would assume the 10TE is also.
#9 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 25 September 2024 - 12:59 PM
Sears 4540?  Do you have a picture of it?
#10 Cavs56
Cavs56
Posted 25 September 2024 - 01:03 PM
It says 44540 but someone here said I didn’t need the extra 4. Basically a Towa 339. It has outstanding optics. It’s the one I got on SGW for $7.
#11 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 25 September 2024 - 01:44 PM
If you prefer the long skinny draw tube that is ok.  I don't care for it.  Its VB is for .965" eyepieces, and you have to make an adapter to use 1-1/4" eyepieces.
The others, like the ATCO or the SYW, they don't have the long skinny drawtube, and the Vixen style 1-1/4" VB screws right on.
The mount on the 339 looks like the standard mount that would come with 60mm scopes.  But I have heard that it was larger, but I would like to see them side by side, as I don't believe so.
So is this the scope you're talking about.  There are many posts on 339's:
https://www.ebay.com...kevt=1&mkcid=28
  • Kasmos likes this
#12 Kasmos
Kasmos
  • Loc: So Cal
Posted 25 September 2024 - 03:07 PM
I'm with you on those skinny draw tubes. No good options for a 1.25" VB, can tend to introduce sag, and scopes with a long main OTA tubes just looks better!
Edited by Kasmos, 25 September 2024 - 03:30 PM.
  • Bomber Bob and Garyth64 like this
#13 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 25 September 2024 - 03:20 PM
I'm with you on those skinny draw tubes. No good options for a 1.25" VB, can tend to introduce sag, and scopes with a long main OTA tube just looks better!
IIRC, I had to add a thin felt strip to my Sears (AO) 6336 to use Johann's Unihex.
#14 grif 678
grif 678
  • Loc: NC
Posted 27 September 2024 - 01:55 PM
I just missed out on a rare Tasco 80mm F400 short refractor. I had been looking this quite a while. I bid on it from Good Will for about a week. This thing looked mint, the newton rings shown in the objective were perfect. I was watching as the time came to a close, and with 10 seconds, I bid $10 above the highest bid, but the signal came u and said that I lost.
This setup had all kind of accessories, circle V also. Really hate I missed out on this one, will probably never se another one. I have found a 60mm F300, but I wanted the 80mm.
#15 Kasmos
Kasmos
  • Loc: So Cal
Posted 27 September 2024 - 02:25 PM
I guess it wasn't the incomplete one on SGW recently discussed in the ads thread. You might be interested in the comments on them being hit and miss. link below
https://www.cloudyni...ads/?p=13706571
  • grif 678 likes this
#16 grif 678
grif 678
  • Loc: NC
Posted 28 September 2024 - 01:10 PM
This one was the complete setup, with original box and case and all eyepieces, barlows, diagonal etc that came with it when new.
He got it for $96.
#17 deSitter
deSitter
    Still in Old School
Posted 28 September 2024 - 01:49 PM
The initial 4- must have been a Sears departmental thing. The badge on the 6344 says 4-6344 and the 4540 4-4540.
-drl
#18 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 28 September 2024 - 03:56 PM
-drl
ok, but I can't find a Sears 4540. I've seen a 3-4454, and a 4-4454, but what is a 4540?
A Sears 4454 is a 80x1200 scope, and they are Circle T.
Edited by Garyth64, 28 September 2024 - 06:14 PM.
#19 deSitter
deSitter
    Still in Old School
Posted 28 September 2024 - 04:24 PM
ok, but I can't find a Sears 4540. I've see a 3-4454, and a 4-4454, but what is a 4540?
Oh no idea. I don't know any of those numbers other than the 4454.
-drl
