Posting this to show how SQM changes due to the properties of the air above you. I forced myself up near 4 am almost every morning earlier this September to take advantage of a stretch of clear skies.
Procedure:
In a NW suburb of Montréal, using my basic SQM meter, at the same spot from my roof, with the same method (a minimum of 12 readings per session, minus spurious readings), I took down the mean or mode at zenith in mags/arcsec2, the limiting magnitude with my best eye-glasses and noted the sky conditions. The job was made pleasant by glancing at the winter stars with Jupiter & Mars.
Adding the actual weather parameters recorded & archived in a field just over 5 km (~3.33 miles) away at Montréal's International Airport, at an elevation of 36 meters (118 feet) above MSL, it's an official Environment Canada recording station operated by NAV Canada.
Also posting a short gif (about 1½ hours worth) painstakingly collected for the period of observations to show the influence of air sector. It's the IR showing temperatures. Visible loops are impossible at night. Scale in °C is shown at the gif bottom.
End Procedure.
Observations:
For the first time since late June, a flow of Polar air had invaded the North American mid-latitudes on September 1st, (and the day before), 2024. I posted an IR GIF here for the entire day of September 1st '24 showing the low that developed, complete with double cold-fronts and marked air types & flows. For the next 16 days, I was under the influence of either sub-tropical, modified sub-tropical and modified polar air. True tropical air having finally receded far south (good riddance), but unfortunately, the sub-tropical air transferred smoke from western regions of the US.
From the marked tiny blue X in the 2010 ISS shot, I got the following sets of SQM readings. Each gif that follows shows the same spot as a white dot near center.
[attachment=2676768:Montreal-December-24-2010_ISSO.jpg]
September 3, 2024, (pre-dawn) near 4:30 am EDT:
SQM = 17.93 mag/arcsec2
Mag limit was at magnitude 4.5, Nu Andromedae, fairly easy by averted vision. Superb sky. A few comments posted right here.
Montréal YUL NAV station:
LocalTime/Temp/Dewpoint-Temp/R.H./Wind-direction/Speed/Visibility/BaroPressure/Conditions
4am LST, 10.8°C, 6.7°C, 76% RH, 300 degrees, 11km/h, 24.1km, 101.94 kPa, Clear
5am LST, 11.0°C, 7.6°C, 80% RH, 230 degrees, 8km/h, 24.1km, 101.99 kPa, NA
September 4, near 4:30 am EDT, 2024:
SQM = 17.54 mag/arcsec2
Mag limit 4.0 by averted vision easy, Nu Andromedae (mag 4.5) not discerned. Fair zenith, thicker horizons, probably smoke. Warm front in the north already pushed out crisp cooler air.
4am LST, 14.3°C, 11.7°C, 84% RH, 250 degrees, 12km/h, 24.1km, 102.32 kPa, Mainly Clear
5am LST, 14.5°C, 11.6°C, 83% RH, 260 degrees, 14km/h, 24.1km, 102.38 kPa, NA
September 5 (pre-dawn), 2024:
SQM = 17.63 mag/arcsec2 near 4:40 am EDT.
Mag limit 4.0 by averted vision (Gamma Trianguli) but with difficulty. Smoke at high levels is certain, horizons obscured and bright stars (Sirius, Rigel & Procyon) not twinkling. Better at zenith.
4am LST, 16.8°C, 12.7°C, 77% RH, 180 degrees, 7 km/h, 24.1km, 102.38 kPa, Clear
5am LST, 15.6°C, 12.6°C, 82% RH, calm, 0 km/h 48.3km, 102.39 kPa, NA
September 6 (pre-dawn), 2024:
SQM = 17.82 mag/arcsec2, 4:30 to 4:45am.
Mag limit 4.5 but with good difficulty. Frontal boundary approaching, but flow from south & south-east ushered in cleaner air than past two mornings. Visibility shown on NAV data as 48.3km for 5am.
4am LST, 17.0°C, 12.7°C, 76% RH, 160 degrees, 17 km/h, 24.1km, 101.56 kPa, Clear
5am LST, 16.8°C, 12.5°C, 76% RH, 170 degrees, 15 km/h, 48.3km, 101.53 kPa, NA
Sept 7, '24: Cloudy by Friday night the 6th through most of the morning hours. Clearings surprisingly dark for marm-sector air in am hours (Sept.7th). No serious check, but by quickly finding Triangulum Mag limit was near 4.0. Warm 18°C near 4am, strong Low-Pressure system developing just south of James Bay.
4am LST, 17.9°C, 14.7°C, 81% RH, 150 degrees, 17km/h, 24.1km, 100.56 kPa, Mainly Cloudy
5am LST, 17.4°C, 14.6°C, 84% RH, 140 degrees, 15km/h, 24.1km, 100.50 kPa, NA
No loop.
Sept 8, '24: After a fair amount of rain into the evening of the 7th, some clearings late. Up near same time, strong flow of cP air but lots of sheered low clouds with higher variable cloud. Dark skies seen with clearings. SQM near 17.70 m/arcsec2 with clouds. Mag limit at 4.5, clearings were brief, very windy and the temperature was a refreshing 7°C (45°F). Later in day on Sunday Sept 8th, temperature reached only 13.1°C for max. Didn't drop much later at night, 11.0°C by midnight, and all cloudy.
4am LST, 7.3°C, 4.8°C, 84% RH, 270 degrees, 25km/h, 24.1km, 100.43 kPa, Mostly Cloudy
5am LST, 7.6°C, 4.6°C, 81% RH, 260 degrees, 20km/h, 24.1km, 100.46 kPa, NA
The loop is for the entire night of Sept 8th, 2024..
September 9th, Monday morning, 2024:
SQM was around 17.78 m/arcsec2 but clouds in west encroaching.
Mag limit at least 4.2. Mostly cloudy with good clearings for 4 to 4:30am. Pi (π) Aurigae, at mag 4.26 quickly spotted (M3 type star actually appears brighter than listed).
4am LST, 11.9°C, 6.9°C, 72% RH, 240 degrees, 19km/h, 24.1km, 100.88 kPa, Mostly Cloudy
5am LST, 11.6°C, 7.5°C, 76% RH, 250 degrees, 18km/h, 24.1km, 100.88 kPa, NA
SQM was a mean of 18.02 m/arcsec2
4am LST, 8.4°C, 6.8°C, 89% RH, 230 degrees wind, 5km/h, 24.1km, 101.23 kPa, Clear
5am LST, 8.9°C, 6.5°C, 85% RH, calm, 0km/h, 24.1km, 101.30 kPa, NA
Sept 11th, at 4 am, 2024:
SQM mode (very common reading) 17.66 m/arcsec2. Clear but bright all horizons, Sirius dimmed & not twinkling.
Mag limit Pi Aurigae 4.26 with averted vision, but Tau Aurigae and Nu Andromedae both suspected at 4.5. Star 1 Geminorum ok at 4.16. Warm front is pushing in some smoke from the north into my east horizon
Later at 5am, very similar except all around horizons appeared even brighter & more obscured. Felt quite humid. SQM 17.72 as a mean. This time 4.5 mag Nu Andromedae not suspected as it was lower.
4am LST, 12.3°C, 10.2°C, 87% RH, 250 degrees, 9km/h, 24.1km, 101.62 kPa, Clear
5am LST, 11.5°C, 9.9°C, 90% RH, 260 degrees, 7km/h, 24.1km, 101.66 kPa, NA
Not Finished Yet. Please refrain from replying.
This is an appreciably difficult post to assemble & double-check.
Edited by GeorgeLiv, 26 September 2024 - 10:02 PM.
