Def GPS and autoStar II says that it acquires lock. Or it least there's no error.
So you're saying that it appears to be aligned correctly on the pier? The north south arrows you put on are correct.
Are these the instructions you are following?
If the telescope is reasonably well aligned with the pole, very little use of the telescope’s Declination slow motion control is necessary. Virtually all of the required telescope tracking will be in Right Ascension. (If the telescope were perfectly aligned with the pole, no Declination tracking of celestial objects would be required.)
For the purposes of casual telescopic observations, lining up the telescope’s polar axis to within a degree or two of the pole is more than sufficient: with this level of pointing accuracy, the telescope’s motor drive will track accurately and keep objects in the telescopic field of view for perhaps 20 to 30 minutes.
You can check if the declination is set at true 90°. Look through the eyepiece and rapidly slew the optical tube on the R.A. axis. If all the stars rotate around the center of the field of view, the Declination is set at 90°. If the stars arc out of the field of view, slew the optical tube on the Declination axis until you achieve the centering effect.
Align tick marks to set the fork arms to 00 H.A. position.
Begin polar aligning the telescope by locating Polaris. Finding Polaris is simple. Most people recognize the “Big Dipper.” The Big Dipper has two stars that point the way to Polaris. Once Polaris is found, it is a straightforward procedure to obtain a rough polar alignment.
To line up with Polaris, follow the procedure described below. Refer to the instruction sheet included with your equatorial wedge for information about attaching the wedge to the telescope and also about using the azimuth and latitude controls.
1. Select "Setup: Telescope" from the Autostar II menus. Press ENTER. Scroll to
"Telescope: Mount" and press ENTER. Scroll to "Scope Mounting: Polar" and
press ENTER. The telescope mount is now set to the polar mode.
2. Press MODE until "Select Item: Setup" displays. Press ENTER. "Setup: Align"
displays. Press ENTER. "Align: Easy" displays. Scroll to "Align: One-Star" and
press ENTER. Autostar II now prompts you to set the telescope in the polar home
position.
Using the bubble level of the wedge, adjust the tripod legs so that the bubble is level.
Set the wedge to your observing latitude.
Using the Up and Down Arrow keys, rotate the telescope tube in Declination so that the telescope’s Declination reads 90°. See SETTING CIRCLES, page 50.
Loosen the R.A. lock, and rotate the fork arms to the 00 position H. A. : Move the forks arms so that center tick mark on fork arm base aligns with the tick mark on the base.
Press ENTER. The telescope slews to Polaris.
Use the azimuth and latitude controls on the wedge to center Polaris in the field of view. Do not use the Autostar II handbox during this process.
When Polaris is centered, press ENTER. The telescope is now polar aligned.
See AUTOSTAR II POLAR ALIGNMENT, page 54, for more information.
At this point, your polar alignment is good enough for casual observations.
