Hey, DR.
I use an EdgeHD 8" at f/10 unguided on an AM5 mount using SharpCap with up to 30s exposures. We have the same camera. It works fine, although I would have some concerns using an ASIair. Here are the issues,,,
- I try to achieve PA error at 2' or less. Still, I can get some drift. SharpCap has a feature where it will recenter the stack if it detects drift of more than x pixels... I usually use 50. On a typical evening it might reset once every 15 minutes or so. Will an ASIAir do that?
- While tracking is quite accurate, generally, there is the chance of semi-periodic spikes. You can deal with that by setting a pretty tight FWHM filter in SharpCap... On the odd spike it will get filtered out. In my case, made more feasible by observing off of a 12" concrete pier that normally delivers extremely consistent FWHM measurements. Does ASIair support FWHM filtering?
- Dithering is very important with an EQ mount to avoid walking noise. SharpCap has a setting where it will dither x pixels every y minutes of cumulative exposures. Will an ASIair dither without guiding?
If you can deal with those issues with your ASIair, I would say no problem, esp given the improved accuracy with the AM5N. If not, consider coming over to the Dark Side (i.e. SharpCap).
Edited by mgCatskills, 02 October 2024 - 06:46 PM.
