Having made a few sketches and finding it very enjoyable it is time to take the next step.
For my very first attempt did not study much and tried it with the simplest of tools. Things went pretty well. From that learned several things. Then of course began some internet research. Mostly here on CN.
For my first refinement I improved my clipboard light and purchased proper HB pencils. These two things a huge help. This is where I am at right now.
Here is my observing setup.
Have my DOB set up for observing while standing. This from my previous flitting from one DSO to another. I can see the need for an observing chair in my future.
I keep everything I need in a specific place on my table. For my last session forgot my pencil holder. A block of wood with holes in it,
For my clipboard repurposed a gooseneck from my soldering holder. The red light taped on and a makeshift light shield in place. The light has two settings. Very bright and still too bright. So taped some paper towel over it. It is still too bright. (The clipboard works well, however have seen David Grays drawing box. Have made a mental note and considering building one.)
I am left handed. At the eyepiece the clipboard held resting on my right forearm. I am fortunate to be 20/20 in my left eye but need bifocals to see close up. When drawing I need to bring the clipboard up so it is at most 8" away. I can observe with or without glasses. However without provides the best view.
Cutting to the chase, my primary problem is my light is too bright. However if I dim it to where I think it needs to be I am not going to be able to properly see what I am drawing. Here is a simulated view.
Thinking at this point to change to drawing on black paper at the eyepiece. Thinking I will have increased contrast and can reduce the light.
I have done some basic study of the Mellish technique. For those who use it are you using the brushes and powder at the eyepiece? So far I make a rough sketch, make notes and redraw the next day. Trying to wrap my brain around using a brush at the eyepiece. Living in Minnesota dew is a problem.
I also at this point prefer to use as little computer processing of things. Be nice not to have to invert images.
There you have it! My goal is to pick your brains to avoid a long learning curve to find the right approach, materials and methods. I appreciate your help!
John B.
