Goofi's Imaging Challenge, October 2024 - M33 Triangulum Galaxy
76 replies to this topic
#1 nikm
nikm
  • Loc: Wenatchee Valley, WA
Posted 02 October 2024 - 11:01 AM
The October 2024 Challenge is now open. The target this month is the M33 Triangulum Galaxy. To reduce the number of stickies, please submit your entry to this thread.
The Rules will remain pretty simple:
-Your Equipment
-Your Data, Captured This Season
-Your Processing
-One Entry Per Member
-Only post your FINAL image. Please display an image in your post, not just a link!!
NO general discussion in this thread. Your post should only contain your image and appropriate info. There is a separate thread for discussion.
To increase participation over such a diverse group, the winner will be selected by random drawing.
Entries must be submitted by midnight, eastern time, on October 31 and I will try to announce the winner sometime after November 1.
If the selected winner does not reply and pick a target with-in 3 days of the winner being announced, the Mods will then select the next target.
There is now a companion thread that runs parallel with the imaging challenge each month. This thread will be for general discussion on the corresponding months imaging challenge target. This thread will be very informal and relaxed and will be treated just like any other thread in the forums. Here is where you can post questions on processing, get help finding the targets location, post a preliminary "final" image to get feedback, etc. The only thing special is that I will be pinning it every month and each months companion thread will be titled in the same way for easy finding and searching. Since this is informal the mods will NOT be starting this thread. We will leave it up to the general membership. So it could take a couple days for someone to start it and for a mod to pin it. So please be patient if you don't see it up day one. Who ever starts this thread please PM me with a link to the thread so I can pin it.
Whoever starts the companion thread should title it to match the following: Target Name - Techniques and Progress Discussion  For example: Rosette Challenge - Techniques and Progress Discussion
Once the companion thread is post, please DM me with a link or put in a mod alert and I, or a fellow mod, will get it pinned.
Note: If I am late announcing, gently nudge one of the moderators in a private note, it helps.
I hope everyone has fun with this one, and with that,
Let The Games Begin
#2 Kerry D. Green
Kerry D. Green
Posted 02 October 2024 - 09:17 PM
Okay, this was my first time capturing, and as mentioned, was acquired early last month.
Equipment
  • William Optics ZenithStar 80ii ED, .8x Flattener
  • Player One Uranus C-Pro (IMX585)
  • Losmandy GM811 with OnStep
  • Wiliam Optics ZenithStar 66SD Guide Scope
  • Meade LPI-G Monochrome guide camera
Capture
  • 721x30s with UV/IR Cut filter (guiding was not working)
  • 159x120s with Optolong L-Ultimate
  • Captured across 2 nights, total of 11h18m30s
Processing
  • Pixinisight
  • WBPP, highest quality, captures stacked separately, 2x drizzle, 17each of darks, flats, dark flats
  • ​RGB:
  • Gradient Correction
  • BXT, Correct Only
  • ImageSolver, SPCC
  • BXT
  • NXT
  • SXT
          Starless:
  • Undo NXT
  • GHS, Color Mode
  • SelectiveColorCorrection to taste
  • ImageBlend, High Pass Filter to bring out lanes
  • NXT
         Stars:
  • GHS, Color Mode, Arcsinh Transformation Type
  • GHS, Lightness Mode, Arcsinh Transformation Type
  • NarrowBand
  • Statistical Stretch
  • Separate RGB Channels
  • PixelMath to create Oiii and Ha
  • RGB+NB
  • Combine RGB and NB Script (Jurgen's Toolbox)
  • Add Stars
  • Selective Color Correction (magenta, yellow, cyan)
  • ImageBlend Script, blur filter, low opacity
get.jpg?insecure
#3 khursh
khursh
Posted 03 October 2024 - 11:32 PM
My take on M 33 was acquired on Aug31-Sep1.
Equipment:
Astro-Physics Stowaway (92mm f~7) with field flattener
QHY268C @-10C
Mach2 unguided
Capture:
240 3-minute subs (12h) with UV/IR cut filter
Processing:
PI:
WBPP
BlurXTerminator
SPCC
NoiseXTerminator
Curves
GIMP:
More Curves, Saturation
Did not choose to remove stars
M33
#4 planetman118
planetman118
Posted 04 October 2024 - 01:53 AM
Really happy how this one turned out. I’m still very much a newb, been working AP since around March. But felt a big jump in progression on this one.
AT102ED scope
D5500 unmodded
AVX mount
ASIAir with ASI178mm guidescope
About 18hrs total exposure, two minute subs, over about 10 nights
Baader MSG and L-Enhance filters
Processed with DSS, SIRIL, NXT, AstroSharp and GIMP.
#5 HappyGalaxymore
HappyGalaxymore
  • Loc: Texas
Posted 04 October 2024 - 10:28 AM
Every time I see pictures of this showing up, I remember that I should spend more time on it, just to forget until I see it again.
SV550 80mm main scope
no filter
SV605CC camera
guided in PHD2 with SV120MM guide camera on Sky Watcher 50mm f/4 scope
AVX mount
all controlled in NINA.
147x120sec subs for total integration of 4.9 hours
Stacked and initial edit in Siril, finish in Photoshop
#6 CTerry
CTerry
  • Loc: Vancouver, wa
Posted 04 October 2024 - 12:12 PM
About 12 hours total split evenly with broadband and dual narrowband.  my processing skills leave much to be desired, but here we are. AT115edt and an uncooled asi533mc.
#7 Oort Cloud
Oort Cloud
  • Loc: New Jersey, USA
Posted 04 October 2024 - 05:15 PM
Here is my entry for this month.  I knew I was not going to image this again this month with the EdgeHD 800, as I am having issues with it, but since I had picked M 33 for this month's challenge target due to its location, I figured I'd go back and take another stab at the little bit of data that I had collected last month on a night where I was just using it to test exposure/gain combinations with my relatively-new 2600MM.  And I learned a couple of things.  Mostly, don't give up on data just because it isn't great.  If you look closely, the stars look pretty bad.  Yet there is still (to my eye, at least, and especially on the full-resolution version) quite a bit of detail showing.  I was particularly impressed with how NGC-604 came out, compared to my last attempt at this target, which was with my C6 and at least 2 or 3 years ago.
This was still really difficult to process, and took lots of very careful background extraction with RBF, lots of very careful stretching with both the Histogram Tool and the GHS module, and some very careful sharpening in GIMP.  And a couple rounds of NR with GX3, one at 80% while still linear, and another at 100% on the near-final image.  And then, of course, a lot of very careful cropping and scaling to get it to fit here.  I had to sacrifice some of the outer arms to keep the detail from disappearing completely.
Total integration time is 83.5 minutes of luminance, and 38 minutes each of red, green, and blue.  Bortle 7
Messier 33 - Triangulum Galaxy
Edited by Oort Cloud, 04 October 2024 - 05:19 PM.
#8 mariemarie
mariemarie
  • Loc: SF Bay Area
Posted 04 October 2024 - 11:26 PM
My 384mm focal length with a 2600MC camera didn't give me a close up view of M33. I could have cropped it but decided I like the look of the galaxy floating in space.
Thanks for the challenge, I wouldn't have gone after this target otherwise!
(click through for Astrobin)
San Francisco Bay Area
Bortle 3/4
3 October 2024
5.5 hours with L-Quad Enhance quad bandpass light pollution suppression filter (164 x 120 second subs)
Processed with SiriL and Starnet (stack, star removal, stretch, star reintegration) and Affinity Photo (NoiseXterminator, sharpening)
#9 Chrisofweden
Chrisofweden
  • Loc: Västmanland Sweden
Posted 05 October 2024 - 10:18 AM
My entry for October (click to Astrobin):
get.jpg?insecure
Captured:
October 4, Bortle 4-ish, Outside temperature: +2 Deg C, Seeing: Average (< 2.5)
Scope: Askar 130PHQ APO refractor (1000mm, F7.7)
Imaging camera: ASI 2600MM Pro @-10c, Gain 100, Bin 1
Guiding: ZWO OAG-L with ASI174MM mini
Focus: ASI EAF
Filters: ZWO RGB, ZWO 7nm Ha
Mount: EQ6R Pro
Control: NINA
Integration: ~5hrs 30mins
- 40 x 120s R,G & B each + 30 x 180s Ha
- Calibration: Bias, Flats, Darks
Software/Processing in PixInsight including:
Blink
WBPP including Auto pedestal, Cosmetic Correction, Local Normalisation, Drizzle x 2, Autocrop
Gradient Correction
RC BlurXterminator - correct only
Channel Combination
RC BlurXterminator
SPCC
RC NoiseXterminator
RC StarXterminator
GHS Arcsinh (stars)
Pixelmath add Ha
GAME scripts
Curves
Saturation
LocalHistogram
Pixelmath rescreen combination for stars
Integer resize
Crop
/Chris
#10 Jasev
Jasev
  • Loc: Hermitage, PA, USA
Posted 06 October 2024 - 02:02 PM
M33 - The Triangulum Galaxy (Oct 5, 2024)
WO GT81 scope, 0.8x F.F., Zwo asi2600mc-pro cam.
EQ6-R pro mount, PHD guiding
Sharpcap, Deep Sky Stacker and processed in Star Tools
3hr.s 44min.s total exposure / 1. min. subs, Gain 100, Temp 0C
Along with 40 dark, 25 flat and 25 flat dark calibration frames
JaSev
#11 danny1976
danny1976
  • Loc: Belgium
Posted 07 October 2024 - 11:25 AM
ZWO ASI2600MC Pro / TSOptics CF 90/F6 + 1.0xFF
ZWO ASI120MC-S / ASTOptics 30/f4 mini guide scope
Skywatcher EQ6R Pro, PHD2 guiding and dithering
APT, Sharpcap pro, Siril, Photoshop, StarXterminator, NoiseXterminator, BlurXterminator
Bortle 5
363x180s = 18h  no filter
60x300s   = 5h   L-eXtreme
120x60s   = 2h   stars
I think galaxies are difficult to process. This is my latest version.
#12 cwgreeff
cwgreeff
Posted 07 October 2024 - 03:10 PM
2024/10/03
Equipment
Canon EF 75-300 at 140mm
Canon T7 unmodified
OG Star Tracker
Capture
244 x 30s no filter
20 each darks, flats, bias
Processing
DSS, Siril, Starnet, GIMP, MS Photos
#13 Garvis
Garvis
  • Loc: Clinton, NY
Posted 07 October 2024 - 09:22 PM
Hello CN,
Here is my take on M33:
Telescope/Lens: Stellarvue 80 APO Triplet – Lomo lens
Mount: EQ6R-Pro
Autoguider: ZWO ASIair Pro
Guidescope: ZWO 60mm
Guide Camera: ZWO ASI290 mini
Main Camera: ZWO 183MC Pro – cooled
Cooling: -10
Gain: 111
Filter: IDAS D1 – 2” w/Flattener
Lights: 39 @ 180sec each
Iteration Total: 1hr 57mins
Dark: 20
Bias: 200
Flats: None acquired
Processing Software: PixInsight
Thanks for looking,
Garvis
Edited by Garvis, 07 October 2024 - 09:23 PM.
#14 starslicer
starslicer
Posted 08 October 2024 - 08:25 PM
Hyperstar's tend to make things glow. It certainly did here so the generalized hyperbolic stretch after starXTerminator came in handy this time.
C6 with Hyperstar
UV/IR Cut
Pixnsight
Photoshop
Bortle 6 or something, I try not to look because its depressing
(480)60"
get.jpg?insecure
Edited by starslicer, 08 October 2024 - 08:40 PM.
#15 TheStarsabove
TheStarsabove
Posted 08 October 2024 - 08:29 PM
C6 with Hyperstar
UV/IR Cut
Pixnsight
Photoshop
get.jpg?insecure
Wow! What is the integration time, may I ask?
#16 acrh2
acrh2
Posted 09 October 2024 - 12:14 PM
Askar 120 APO, 840 mm focal length, f/7, 0.93 arcsec/pixel.
ASI2600MM Pro, gain 0, 120 s subs dithered every other sub.
Astronomik Typ2C LRGB, Antlia 3n nm Pro Ha filters.
Bortle 5.5, no Moon.
LRGBHa = 13, 5, 5, 5, 7 hours = 35 hours total.
#17 Sean McDaniel
Sean McDaniel
  • Loc: richmond, va
Posted 09 October 2024 - 11:40 PM
Askar 103 APO
ASI2600MC Air
Optolong L-Quad Enhanced
PixInsight
~6 Hours
#18 sub-zero
sub-zero
  • Loc: Cleveland, OH
Posted 10 October 2024 - 02:15 PM
2 hours on M33
Lights 40 x 180s
Darks 40
Flats 40
Dark Flats 40
Siril and PS for processing.
get.jpg?insecure
#19 powerslide
powerslide
  • Loc: Sydney, Australia
Posted 10 October 2024 - 07:51 PM
My First attempt at RGB+Ha.
Scope: C8 SCT
Mount: EQ6-R
Camera: ASI2600MC
Acquistion through Nina
Stacked in WBPP & Processed in PI
100 x 120 s on UV/IR
40 x 180 s on ZWO Duo (Red Channel Only)
M33 3HrRGB 2HRHa
#20 DFW Guy
DFW Guy
Posted 11 October 2024 - 09:05 AM
M33 - TRIANGULUM GALAXY - WIP (2024)
I still want to add more data but since it's going to be a week or so due to the moon I'm going to upload as-is right now.
Equipment:
  • 12" Meade ACF LX850 f/8
  • ZWO 2600MC Pro
  • Celestron CGX-L
  • ZWO OAG-L
  • ZWO 220mm Guide Camera
  • ASIAIR Plus 256GB
Capture:
  • 1615 x 180 no filter
  • Captured across 9 nights, total of 80h 36s
Processing:
  • Stacked in Sirilic, calibrating each shooting session before combining them in final stack
  • Background extract/denoise using Graxpert
  • Photometric calibration using plate solving
  • Green noise reduction
  • Auto stetch
  • Asinh transformation
  • Color saturation
get.jpg?insecure
#21 manfromplanetx
manfromplanetx
  • Loc: OH
Posted 11 October 2024 - 03:34 PM
M33 - First Entry into Montly Challenge
Equipment:
Explore Scientific 102CF FCD100
ZWO AM5
Player 1 Posiden C
Svbony 220, Optolong Quad Band
Capture:
110 x 300 sec Svbony 22 - 9.17 hrs
165 x 180 sec Optolong Quad Band - 8.25 hrs
10/6/24 and 10/7/24
Processing:
PIxInsight
BlurXTerminator
NoiseXTerminator
StarXTerminator
MPX
#22 bbasiaga
bbasiaga
Posted 11 October 2024 - 08:07 PM
M33 - This is my first monthly challenge as well.
Equipment
SV130T
AP Mach 2
ZWO2600MC Duo
Capture
215x3min subs, Gain 100 offset 50, Cooled to 0C  all broadband no filter (besides built in UV/IR)
20 darks
30 Bias
30 Flats
Taken 10/6 and 10/10 2024
Processing
Stacked in Siril
PCC and SCNR in Siril
Gradient removal in GRAXPERT
Starnet star removal
Stretched using ArcsinH and GHS in Siril
Denoised in Astrodenoise PY
Color correction and a couple of the Riston Tools in Affinity 2
Stars stretched in Siril
Slightly modified in Affinity, and recombined in Affinity
Click for the larger version.
Edited by bbasiaga, 11 October 2024 - 08:09 PM.
#23 odddiv
odddiv
  • Loc: TN US
Posted 12 October 2024 - 09:06 PM
Triangulum HSO RGB 10.12.24
Skywatcher Evolux 62ED with Flattener/Reducer (F5.8)
Touptek / Risingcam ATR3CMOS08300KPA IMX585 Cooled Color
ZWO AM5n - TC40
OGMA EFW
OGMA OAG w/OGMA GP678C Guide Cam
ZWO EAF
Bortle 8/9 - Memphis, TN
Optolong UV/IR - 445 2 minute exposures : 14.8 hours
Askar D1 - 435 2 min exposures : 14.5 hours
Askar D2 - 492 2 min exposures : 16.4 hours
Shot between 10/6-10/11 2024
Stacked and processed in PixInsight
Final image is a blend of RGB from the UV/IR images and the HSO output of the two Askar narrowband filters.
ADBE
blurX
StarX
NoiseX
GHS
DBExtract (Askar images)
LRGBComb (Askar images, HA mapped to L)
ImageBlend
Curves tweaks
PixelMath to re-add stretched RGB stars
#24 nwcs
nwcs
  • Loc: Tennessee
Posted 13 October 2024 - 03:58 PM
I finally took to this target in September and a week ago with an unprecedented stretch of clear skies at night. Full details and BIG image are on https://www.astrobin.com/rwe3wn/B/ but the basics:
28'22" capture time
90mm SV Raptor
ASI cams and mount
PixInsight
#25 southernharry
southernharry
  • Loc: Woodstock, GA
Posted 13 October 2024 - 05:37 PM
Finally clear skies but here comes the moon.
AT 130EDT @ 910 mm, Astronomik L-3 UV/IR filter
180, 1 Minute Exposures - 3 Hours Total
ZWO ASI533MC Pro at 0 degrees C
AT 60 Guide Scope with ASI178 Guide Camera
Processed in APP, Affinity Photo, and Photoshop Elements
EQ6R  and PHD2
M 33 crop Lpc Cbg Csc St NX PS PS
Edited by southernharry, 14 October 2024 - 02:33 PM.
