I have the following setup for my planetary imaging:
- Celestron Edge HD 11 on Skywatcher EQ6R-pro
- Televue 2.5X Powermate
This combination gives me a focal length of 7000mm at f/25.
- ASI 585MC (primarily for its larger sensor size)
This gives me a resolution of 0.09 "/px with no binning and 0.34 "/px with 4x4 binning.
I mostly do all my imaging from our backyard (Bortle 6-7 skies) with Good/OK seeing.
Problem: My images end up being soft (example).
What I've tried so far:
- Dialing in the collimation and focus (get much better visually)
- My workflow is pretty standard - pipp, autostakkert, registax (or pixinsight)
Questions:
- Am I better off not using the powermate (or a 2X instead of the 2.5X)?
- Should I consider a different camera with a larger pixel size (585 has 2.9micron pixels)?
- Should I always consider binning 4x4?
Would greatly appreciate any insights as I've run out of ideas trying to get sharper images.
Edited by sjanarth, 06 October 2024 - 10:05 PM.
