UPDATE on C2-SWAN, visual at 82X in 152mm RFT, 29 Oct, 2024 between 1715-1820UT:
11nm NT6 (TV Nagler) for 82X (81.8X) in the scope. Seeing held pretty well with a couple of "OMG!!!" moments in between!
I don't even know where to begin...
Well, let's start with AR 13872 and 13873 areas:
Whoa! What a fun region to play in today on the sun with this filter!! Seeing was Pickering 8/10 average, with periods of 9+/10. Temp ~3C. A light breeze <10km/h for the majority of the session, was crisp but tolerable. That region --- well first off, during the session, pores and small spots dotted all over the place - between the two larger groups, and off to the eastern side of AR13873, trailing - associated with most of these "collections" or clusters of small spots was that "shading" I refer to - really obvious during the session - inter-dispersed with some plage structure in between some of them. More on Plage in general later. The penumbral region by AR13872's big spot had a gap - which started as two bright voids, bordered on the upper (N) side by at least 3-4 pores. Over the session, this dual void merged and expanded, and two of the 4 main pores merged (or approached towards each other such that my resolving at that power could not fully separate them anymore), with another smaller pore off to the outer edge of this region. A range of penumbral filamentary changes were also visible here: they "parted" a bit proximal to this merging penumbral void, and an extension mid-way off the N central edge formed. Inside the main Umbra, some hot/bright spots showed well for about 1/2 the session when checked over the ~1h period. Became general hotter near the rim by the "penumbral void" area, and was developing into a full light bridge/cleft between the umbrae. Very cool stuff to follow in REAL time!
Okay - there was more, but you get the idea; now for AR 13875:
That was IMO one of the two big treats today! That central AR has mostly smaller spots and dotted with a couple of small and larger pores from near disk centre towards the NW mid disk. During better to the best seeing, this region -well- exploded with subtle and not-so subtle structure - mostly fine plage networks and granulation... temperature/brightness differences in some small, compact areas surrounding the main insolated larger spots - micropores were coming and going in a 25 minute timeframe. Not totally disappearing but subtle changes in appearance and contrast. Awesome. Some of this may have been "seeing effects" too, but in general, repeated checks DID show subtle changes at the scale of view. There appeared to be some additional dark regions surrounding the main larger spots of this AR (13875)...
AR 13874's two larger spot umbrae touted some brighter central areas, the trailing one was a sort of "V" shape, following the shape of the border a bit; the other spot ahead of the bigger one, had most of the umbral area looking a bit brighter, changed intensity over the hour session during "spot" (punny!) checks. The frontal large spot of this group also had a tenuous bright region, which I say because for some reason, this spot was the toughest to follow finer detail - sometimes seeing effects really plagued this one. However, during the best seeing, this was resolvable, as a "stripe" following the umbral cleft on the N side. Subtle facular Plage between the areas and small pores and spots dotted between the two larger regions, with a shaded thin "trail" of darker granulation coming off the front spot for ~2/3 the separation distance or so. Very novel, and not as well seen in Na light, though I did not run Na today - it likely would have shown too. (?)
AR 13868's big lone spot had very nicely developed penumbral fans - very symmetrical and following the shape of the spot umbra. A nice two pore or small spots could be made out during best seeing - one larger one for sure, and the other smaller one was pretty much in contact with the umbra, so may have been an extension. hard to tell there at 82X. Still neat...
LOVELY Plage network along the leading western side through the departing 13863's twin small spots. DEEP bright areas, and one lone bright round, isolated section approx 1/3 way from the limb to AR 13874's leading spot. subtle plage network structure, showing as a less intense bright, and blanker (lack of regular granulation), followed from there through into between mid disk, where the small spot/pores were seen mid-way from AR 13875 and 13876. Best seeing had this structure showing in an almost-overwhelming way today. (!!)
AR 13877's small spot group had lovely "shading" showing also esp. towards the west side, below the frontal spots, towards AR 13873 - sort of obliquely diagonal on the west side before the "border" (?) with the '73 group's trailing spot. Some pores above this as well came and went with seeing,
Finally, AR 13878 and AR 13879 (new big spot - assuming it is to be 79); AWESOME plage structure throughout both regions - connecting by tendrils of plage (!!!) - the other big treat of the day... Showed really well, including the new big spot's umbral extension to the eastern limb - Penumbral structure and plage to JUST near the limb edge with best seeing - really one of the best limb views I've had in some time. Just awesome!!!
So, those are the main highlights. As always, for brevity , I'll stop there, except to say that these C2-SWAN filters are certainly not at all a disappointment. VERY impressed as visual filters, and suspect a few shooters may get some surprises in the future.
Final note: I am communicating currently with two major well-known filter suppliers to offer an "enhanced photosphere" filter set. Obviously with Na/Mg in the mix. One so far has shown significant interest, TBD.
I am not/will not be getting anything ($$) for these, as compensation, so I can mention that this currently interested supplier is Player One.
If anyone is interested in "nudging" them along, please feel free to ask if a set like this could be a possibility. Remember, Na CAN also be used for Mercury atmospheric studies, Io flux-studies in bigger scopes, Comet Na tail viewing and shooting, and so on, and NO ONE currently offers a Na filter!!! Since LED lighting I cannot believe the non-Na line trend still. HPS/LPS lighting is all but gone in 90% of the civilized world.
The added plus here is a dedicated NB (~5-6nm wide) Mg filter to pass all three bands. Big help for Larry! LOL! The more queries, the more likely they are to offer these. Hopefully we may have a set in the not too distant future, but for now, it's the C2-SWAN for this band... and these are doing pretty darned well, at least in my visual system, so far! More to do, but awesome... Ultrafine filaments are a BIT easier so far to see in Na, but Mg light is also VERY good in this regard! Likely a color-contrast thing. Both are fun though!
Cheers, clear skies, and good solar!
Darren
Edited by Spectrum222, 29 October 2024 - 11:27 PM.
