I would suggest sit back in the daylight one day and take a critical look at your scope to identify all the things you could relocate or change that could influence the result. Looking for anything that has a reflective surface close to right-angles to the light path, and have a darn good look at the anti-reflective coating.
These include the cover glass of the camera, as well as filters, reducers and corrector plates (if any).
NB one aspect of the design of modern multi-element camera lenses is that they use multi-layer anti-reflective coatings, and if you look into them, each surface exhibits a reflection in a particular (and different) color. This is deliberate - to reduce the intensity of ghost images at the focal plane from double-reflections.
If you are using reflective (interference) filters, they are also highly reflective, so anything reflected to them will be reflected back. Hence the ghosts in your images may be due to a bounce from the camera cover glass to the backside of the filter, and then back to the camera. Putting the filter closer or further from the camera will confirm this by altering the size of the ghost. It's out-of-focus by virtue of the additional path length involved. It also suggests multilayer dielectric reflective filters should have the most reflective side towards the camera sensor.
Apart from anti-reflective coatings, other ways to eliminate ghosts include tilting flat surfaces (i.e. filters) so reflections are deflected well off to one side, or make them curved (not flat), so that a double-reflection is diffused very widely rather than causing a ghost. Unfortunately no-one makes filters with spherical surfaces, and unfortunately I dont think it has occurred to anyone yet to make filter trays with a deliberate tilt angle.
Edited by luxo II, 03 November 2024 - 10:30 PM.
