Solar Corona
32 replies to this topic
#26 George9
George9
Posted 08 November 2024 - 08:04 PM
Yes, they are soft-coated filters. Ideally, I would cement them together, but I have not yet and they work well enough.
The key thing is that they are behind the cone. There I agree an ITF or whatever back there would be fine.
I thought you were referring to an ERF in front of the objective. That's where the scatter is key. I have not tried an ERF in front, but I can give it a shot. But let me give you an example. If I am observing and the corona kind of disappears, perhaps not completely, but it becomes indistinct and faint, then I know to check the objective. I will remove the dust shield and find a single piece of dust on the objective. If I can see it, then it is too big. I take my blower and blow it off, and the corona comes back. The degree of harm depends on the size of the dust (I think to the fourth power, we calculated). If it is microscopic, it doesn't matter. But if you can see it readily, then it can make a huge difference. It makes the whole background brighter, but it is sometimes hard to tell the difference minute to minute. The corona visibility makes it easy to tell the difference. (Once an insect put a single gossamer thread across the objective, almost invisible except for a glint in the sunlight. That brightened the view many fold and ruined all my negative off-band shots.)
Any kind of coating, hard or soft, is going to introduce scatter and one of these ERF coatings could very well introduce as much scatter as a single piece of duct. I can try putting my Baader DERF in front just to see. Or one of my 2" hard-coated filters. I also worry about whatever they used as a substrate and what scatter that produces.
George
  • BYoesle likes this
#27 Klaus_160
Klaus_160
Posted 10 November 2024 - 02:31 PM
Sorry for the long delay for some of these questions – I was traveling.
As for the discussion around the brightness of the Corona, I can contribute the following:
– I have seen scientific papers where the result is that the E Corona is about .1% to 1% of the total brightness of the Corona. If the total Corona is about 2-5 * 10-6, then the E Corona is about is about 2-5 * 10-9 to 2-5 * 10-8.
– When the old Sacramento peak coronagraph site was still up, they gave absolute brightness in millionths per Angstrom, i.e. if all the light of the green or the red line would be confined into a rectangular sliver of one Angstrom width, the height would be the stated value. These values ranged from 0 to 200 at the very most, very rarely exceeding 100.
- I have really only attempted a direct measurement once, and if I recall correctly the stray light on that day was about 20 millionth and the Coronal brightness about 100 millionth. However, the filter profiles need to be taken into account and I am not even totally sure whether had one or two filters at that time. However, I’m in the ballpark of the Sac Peak measurements.
So the conclusion is that the E Corona is very faint, but if you filter out the right slice of wavelength, it is about 10 to 100 times brighter than the K/F Corona. That is why one uses a filter.
> What type of Polaroid are you using? A regular low cost one may not do so well out at 700+ nm for the K-corona
Just the cheapest of the cheapest Amazon filters. However, I do not go above 700 nm, and I’m pretty sure I tested these Polaroids with filter combination I’m using (i.e. crossed polarizer blocking) and they were okay.
> Hi, with the imx462 mono you should get at least twice the signal for this wavelength (660 nm to 690 nm) compared to the imx249.
Yes, I have considered this camera. I am, however, not really limited with exposure time for the K Corona because of the broad band of the filter. The IMX462 is a great IR camera though, and I have considered using it with the appropriate filters (at 800nm-900nm) because the scattering of the Earth’s atmosphere is much lower there. But then again, I am mainly a visual observer, I am just taking these images because otherwise nobody would believe me what I’m seeing wink.gif
>>>> I’m going to have to field test this- i don't see how having an objective mounted erf will "eliminate" the corona while onband transmission is maintained at 95% on the occulting cone with all the infrared light and uv removed. Baader bessel series filters are very high end and are designed to prevent defects like scatter, reflections and halos. I understand how the high cirrus cloud scatter affect happens, but diminishing them entirely because a modern filter is mounted on the objective does not seem correct. I am assuming you are using two traditional soft coated custom order Andover filters which each consist of two glass plates (sometimes 3), epoxied together (four total in the double stack)- Seemingly, four plates of glass with 2 epoxy barriers of scatter did not have much of an affect on your ability to capture corona with just 20% transmission.
As George said, filters behind the Lyot stop are not the problem, but before they are. Now I have seen prominences with just a red filter through a double glass window, and as George says one can use a cemented achromat to see the Corona, so maybe these modern filters would work. I have never tried one myself.
However our systems work just fine as demonstrated by all the images so I’m not sure what I would gain by adding an ERF. For larger apertures that may be different.
> Can you share the actual spec sheets Andover shipped you for your custom filters? Usually its on a usb stick with a .pdf file attached
They stopped sending USB sticks for cost reasons, just a printed curve now. However there’s nothing special. It is just a one cavity filter with an FWHM of 2 Å.
> Not sure what aperture you are using but you could get that 65 x 65mm square to potentially boost your contrast significantly via a darker background sky- The bessel V is od5.5 blocked out to 1100nm and od3 blocked to 1250nm
The Andover filters should have OD 5 blocking into the far infrared. However, even that is not enough: if the sun is out of focus for other wavelengths you compete with the photosphere which is 10 ^5 times brighter than the Corona, and that over the whole spectrum, therefore much outshining the E Corona even at OD5. So you are correct: when I used a single 2 Angstrom filter, I added another green filter (Meade CCD green) to improve the out of band blocking. Now the second 2 Angstrom filter is taking care of that since they add up to a OD10 out of band blocking performance.
> ill be on the coronagraph team in a couple weeks to test this because im Pretty confident this isnt going to be an issue.
So you are planning to build one? That is exciting. Please report on the progress here and let us know if you need any suggestions.
Klaus
Edited by Klaus_160, 10 November 2024 - 02:50 PM.
  • R Botero likes this
#28 George9
George9
Posted 10 November 2024 - 04:02 PM
I found the specs on one of my filters.
45% transmission
FWHM 1.9A
10% 5.4A; 1% 11.3A
Center 5302.2A at 23C
George
Edited by George9, 10 November 2024 - 04:03 PM.
#29 spicerack0
spicerack0
Posted 11 November 2024 - 06:18 PM
45% transmission
FWHM 1.9A
10% 5.4A; 1% 11.3A
George
i would not risk "cementing" them together because the interference pattern may change the center band frequency just enough so that its no longer onband since it is rated for airindex on the surface-  however i think you would have a great result using an optical couplant. Obviously you wouldn't be able to acquire the dowsil 3067 grease that Mark Wagner uses on his mica etalons  ($500 for 112 grams),   but you could certainly get the cheaper alternative which is clear silicone based index matching gel used for fiber optics. Ive considered using this in one of my systems but haven't pulled the trigger on it yet.  The process is simple in that you just use a book to compress the filters together on a heating pad.  The issue with Andover filters however is the metal surround which prevents the input faces from connecting on the metalized surface.  Are the back faces blocked by the metal?  I know some of their filters are bare glass on the backside so its possible that may work out.
https://www.thorlabs...tnumber=G608N3
#30 George9
George9
Posted 11 November 2024 - 07:30 PM
Ah interesting, thanks, and thanks for the link. I have a bit of a metal rim on both sides of my filters, so I would have to grand that off, then risking moisture leakage into the filter. One side has a bigger rim than the other, but even the smaller side has some.
George
#31 C0rs4ir_
C0rs4ir_
  • Loc: Germany
Posted 13 November 2024 - 03:02 AM
"Yes, I have considered this camera. I am, however, not really limited with exposure time for the K Corona because of the broad band of the filter. The IMX462 is a great IR camera though, and I have considered using it with the appropriate filters (at 800nm-900nm) because the scattering of the Earth’s atmosphere is much lower there. But then again, I am mainly a visual observer, I am just taking these images because otherwise nobody would believe me what I’m seeing"
Has nothing to do with the exposure times, its about getting more information into the images -> more details / smoother images, less background noise with similar exp. times & similar stacked images. (Unless you can use "0" camera gain with the imx249)
We want to see what you are seeing : )
Edited by C0rs4ir_, 13 November 2024 - 04:48 AM.
#32 spicerack0
spicerack0
Posted 13 November 2024 - 11:16 AM
i used to have that asi462mm camera over the summer but ended up returning it because it provide significantly less frames per second than advertised and i dont believe zwo ever issued a firmware update to address that issue (52 frames persecond actual versus 136fps advertised)-  i think christian and several other users also had the same problem.  (i have a very nice pc  with .m2 solid state and ddr5 ram  so i know the problem wasnt computer related performance)
It was an amazing camera and i loved the red light performance, but I just couldnt accept how slow it was compared to the older imx174 half the speed was a huge loss and the extreme quantum efficiency wasnt worth the drop in frame rate for what i was using it for.
I then tried imx678 which has the awesome response as well but again its just anything less than 100fps is way too slow, so i ultimatley ended up returning that one too.  Even with 2x2 bin it wouldnt go above 50fps.  Might just be an issue with ZWO asi series- i never tried the other two brands.
Edited by spicerack0, 13 November 2024 - 11:24 AM.
#33 C0rs4ir_
C0rs4ir_
  • Loc: Germany
Posted 13 November 2024 - 12:01 PM
Im using the Player One version (Mars 2 mono, 250$), no driver issues there with the latest drivers.
136 fps in 8 bit is ok, if you want more you can use a bit of ROI and be quickly at 150+ fps.
Until they finally get some StarVis 2 mono sensors in production the imx462 mono has the highest QE in all useful wavelengths.
