Hmmmm, here is an industrial version with clear data on the bandwidth performance, but it costs a bit more.
https://www.thorlabs.com/newgrouppage9
The picture explaining how this cheap one works makes no sense, it could just be a red filter with a set of polarisers(???), so may not tune with wavelength. If someone has a spectrometer that goes out into the near IR it would be very interesting to measure the actual bandpass and how it varies with the tuning, then we could understand exactly what we’ve got. With NV filtration the strength of the blocking out of the pass band is as important as the band that is passed, as this affects the contrast in the image.
You could do a quick test with a few known wavelength long pass filters (eg 685, 780, 850, 930nm) and an NV unit. Tune this filter to visible red and then pop on the NV with a known long pass as well, then tune the variable filter to longer wavelengths. If it works as advertised then you should begin to see an image as the filter bandpass moves into the long pass filter pass and. Repeating with a different cutoff long pass filter should show that the tune angle needed to reach the known long wavelengths changes.
Peter
