I would like to know how (or if I even can), effectively "park" my mount at the Home position and keep it powered up.
I've a Celestron CGEM-DX mount (c. 2012), HC Firmware Ver. 4.22, Motor Control (both RA & DEC) Firmware Ver. 6.50.
Of all the things that bug me, one is the GOTO Home and Setting Home.
I'd like to GOTO Home and leave the scope powered up, but it continues to track West in RA.
I can't just walk away - the mount is not really "parked" and I don't know how to "park" it (or if I even can).
The problem continues with GOTO Home after a good re-alignment that starts fresh from the Index Marks.
No matter what I do, even if I set set the Home position at the Index Marks, once I start viewing and decide to rest a bit, if I send the mount to GOTO home, if will go the Index marks and then rack West some 5 degrees or so away from the RA "zero" Index mark. The mount just seems to want to lean to the left - and then it continues to track (move) west in RA.
It's almost as if the position of Home is a dialed up star and leaving the mount on that imaginary star just causes the mount to track it as if it were a star.
How can I get my mount to stop rolling back in RA and stay on the Index Mark?
And, how do I actually "park" the mount so it is no longer tracks in RA, and is not engaged in tracking anything - just resting "out of gear" in neutral?
Appreciate all the help this is likely to generate. Jim
