Hi all,
Back in September, I did a bunch of research into obscure and/or recently discovered supernova remnants with the intention of tackling the brightest of them this autumn. That's when I learned of one in southwest Cassiopeia, along its border with Lacerta, that was first "published" on AstroBin less than a year ago.
Nicknamed the "Nereides Nebula" (G 107.5-005.2) by its discoverers, it's currently the SNR with the largest angular size ever discovered by amateur astronomers and is the subject of at least two papers (Fesen et al 2024, Araya 2024) in the last 12 months!
So, I figured by the strength of the O III emission I had a good shot with a friend's 36-inch. Here are my notes:
Oct 4th / 36” / Nereides (G107.5-05.2) SNR in Cassiopeia. Using Lacerta’s brightest stars to guide me to it, I found that at 150x and with an O-III filter there was a surprisingly easy area visible as a softly glowing strip visible on the NW edge of the SNR. I failed to see any of its southern wall and did not attempt the northeast "corner".
Oct 5th / 36” / Nereides (G107.5-05.2) SNR in Cassiopeia. Using Lacerta’s brightest stars to guide me to it, I once again found visible the same part of the SNR that I had last evening. This time though, I searched the NE “corner” of the SNR and found a triangular section visible at 150x with the O-III filter.
Oct 7th / 16” / Both pieces that I had previously seen with the 36-inch are also visible at 100x with O-III in 16-inch f/4.5 dob. Not quite as distinct, but I'm sure it will be seen with less under better skies.
Here is the original chart that I drew up and used at the eyepiece. Note that I did NOT use an actual photograph to not introduce much chance of false positives.
And here is a low-quality copy of the O III image taken by the team who discovered the Nereides SNR and the parts that I've seen marked.
I expect in the next year or two a lot of folks will have seen this one. So, enjoy, and hats off to Marcel Drechsler, Bray Falls, Nicolas Martino, and Yann Sainty for finding and imaging it! We visual folks owe you big time!!
Scott H.
